Help P0335 - Crankshaft Position Sensor
Old Jun 25, 2019 | 09:00 PM
blackcivic11's Avatar
blackcivic11
Hey guys,
So I'm getting a p0335 code when i get into high rpm and the car then goes into limp mode.
Im planning on changing the crankshaft position sensor but I'm wondering if anyone knows the best way to access the sensor to swap it out.
I'ce found ALOT of how tos for g35's but none for the g37..
Has anyone done this and can gove some pointers? Easy access from the bottom?
Thanks!
Old Nov 11, 2019 | 08:59 AM
bean_vq37vhr's Avatar
bean_vq37vhr
I have the same issue.. swapping out my crankshaft sensor this week. I’m also gonna see if my signal plate looks ok.
Old Nov 11, 2019 | 03:16 PM
telcoman's Avatar
telcoman
https://www.google.com/search?q=g37+...aS1mF0M:&vet=1
Old Nov 24, 2019 | 02:45 AM
bean_vq37vhr
I finally got around to swapping the sensor and my car started acting weird. It revs normally as it should in park but in drive it kind of bounces and stutters at 1800 rpm. I successfully did an ecu reset and the problem still persists. I put the original sensor back on and it drives normally again. But the original issue is still there when it goes into limp mode during wot at high rpm (6k to 7k)
Old Jan 4, 2020 | 11:53 PM
needsoju's Avatar
needsoju
Camshaft position sensor B1 was replaced on my car for code P0340. Paid an arm /a leg at the dealership... My symptom was car would not accelerate over 30 mps and and no check engine light on.
Old Nov 5, 2020 | 06:44 PM
Fitz92's Avatar
Fitz92
reving an old thread I’m have THE SAME exact issue what was your fix
Old Nov 5, 2020 | 08:40 PM
bean_vq37vhr
warped flexplate.. after swapping it I’ve been good every since. Have you already tried swapping your sensor?
mirzabaig
37
Jul 23, 2025 08:00 PM
Michael Moheban
23
Mar 7, 2025 05:20 PM
kickin_it
Feb 21, 2022 04:47 PM
Jonesmeister11
Intake and Exhaust
May 16, 2017 01:48 PM
aznwash3wboi
Apr 3, 2013 12:04 PM
