Lag
Old Apr 3, 2011 | 07:45 PM
prankiRL's Avatar
prankiRL
Lag
Hey guys, I just bought myself a 2011 g37 coupe, I have around 330 miles on it is there a reason why my engine lags, or whenever I drive in sport/tip tronic switching gears lags, is it because my engine hasnt broken in yet or what? What do you guys think is this with all G's?
Old Apr 3, 2011 | 10:42 PM
ColaBear's Avatar
ColaBear
mine also has a pretty huge lag during gear shifts (in DS mode) even after the break in period. Since it is not a dual clutch transmissoin, there is no solve for it..
Old Apr 4, 2011 | 01:25 AM
Jallerd19's Avatar
Jallerd19
if its a 7AT there is a flash update from the dealer, I'm not sure if it was just for the sedan or coupe as well.
Old Apr 4, 2011 | 02:52 PM
prankiRL's Avatar
prankiRL
Recently? Because I just picked up my car on the 28th
Old Apr 4, 2011 | 03:00 PM
audtatious's Avatar
audtatious
There is a couple of Technical Support Bullitin's out for lags/harsh 7AT transmissions:
ITB10-075 is for various issues including harsh 2-1 downshifts
ITB09-032b which has to do with 4-3 downshifts
You can find them here: Infiniti G37 Technical Support Bullitins
Old Apr 5, 2011 | 09:11 PM
Sena's Avatar
Sena
ecu flash from the dealer and grounding kit should resolve the issue.
Old Apr 6, 2011 | 08:18 AM
wpmcnamara's Avatar
wpmcnamara
Um, no offense but a grounding kit isn't going to do jack for something that is a problem with the transmission control program. I suspect that why most people think grounding kits help is that it takes long enough for them to install the kit that learned driving profile gets erased, same as doing it via the pedal method. There are a few things that a grounding kit might help, the primary one being alternator whine in an aftermarket audio system. But a grounding kit is not going to fix a lagging transmission or give you a horsepower boost.
Old Apr 6, 2011 | 09:07 AM
IntangibleBW's Avatar
IntangibleBW
Old Apr 6, 2011 | 09:17 AM
ANMVQ's Avatar
ANMVQ
My Coupe has no LAG but I drive it pretty hard.
Old Apr 6, 2011 | 10:53 AM
3Pedals's Avatar
3Pedals
my uncle came out of a 08 g37s 6mt and went to a 2011 g37x vert. when i tell you he is upset with the auto trans compared to the manual, its an understatement. he has been back to the dealer a few times b/c of this "lag", their last resort was to swap out the computer. probably will be the same as when he brought it it, he's just hoping that he had an extra troublesome tranny. good luck to those with this problem!
Old Apr 6, 2011 | 12:20 PM
movinon's Avatar
movinon
I've put 10,000 miles, over the last year, on my 2010 sedan and have experienced no lag, but I have read a lot of posts on the forums complaining about it.
I put most of the miles on at highway speeds and have done a lot of high speed passing on 2 lanes.
If I had experienced any type lag and the dealer couldn't resolve it, I would have got rid of the car immediately.
Old Apr 6, 2011 | 12:21 PM
ANMVQ's Avatar
ANMVQ
Um when did they come out with a X Vert??
Old Apr 6, 2011 | 03:03 PM
3Pedals's Avatar
3Pedals
um, my fault big guy...regardless he's got the same type of problem
Old Apr 6, 2011 | 04:01 PM
11_xS_coupe's Avatar
11_xS_coupe
MIght be a noob question here, but when you talk about the install erasing the learned driving profile is that simply b.c the battery is disconnected for an extended period of time
Im asking b.c i broke my car in fairly nicely, and was wondering if i could just erase the LDP by just disconnecting the battery for while so i can drive hard from the get-go when it starts to learn my driving.
Old Apr 7, 2011 | 08:22 AM
wpmcnamara's Avatar
wpmcnamara
Not to derail the thread too far, but yes you can. You can also reset the stored parameters with some carefully timed pedal presses. Search around, there are a couple of thread on it. One thing to note is that the learning process is a long term thing. All references I have seen imply thousands of miles and it is continual. So, if you do the reset, the go drive hard for the weekend and then sit in stop and go traffic all week, it's not going to do much good. It is trying to "learn" what the most likely thing it needs to do is for a given input by the driver. So your best bet is to drive it consistently.
linvbro
Aug 22, 2016 01:25 PM
kavcheung
Jan 22, 2016 02:40 PM
SLEV3N
General Tech Questions
Oct 17, 2015 05:58 PM
Falker11
Sep 9, 2015 08:53 PM
