Low level of engine coolant
Old Jan 17, 2013 | 04:10 PM
FlState's Avatar
FlState
I've had my g for almost 3 years and a half and I have 24.5 K on it. Since I got this car back in 2009 I noticed that the engine coolant was at the bare minimum line which is marked "min" on the reservoir. I checked the reservoir recently and it has lowered almost to the lowest possible level it can to yet be visible in the reservoir.
Have you guys experienced the coolant lowering through a long period of time? Performance levels haven't changed and the car has never overheated. I just got the Nissan engine coolant and would be filling it up tonight which brings me to the next question. Do you think I should top it off or flush the old coolant and replace it completely. I got the green 50/50 mix.
Thanks for your help.
Old Jan 17, 2013 | 04:20 PM
The reservoir you are looking at is simply an overflow tank. Open your actual radiator cap and check the level there. You can top off the actual radiator and the overflow tank with the 50/50 if needed, but these cars are designed to go 100K without needing a flush.
Old Jan 17, 2013 | 04:25 PM
FlState's Avatar
FlState
Thanks BB, I'll just top off the overflow tank for piece of mind. Where exactly is the actual radiator cap located? How do I know it's had enough engine coolant? I'm a noob I know. Lol thanks!
Old Jan 17, 2013 | 04:33 PM
The radiator cap in in the center of the radiator, just in front of the plastic overflow tank you are looking at. Probably has an sticker on it telling you not to open when it's hot.
eljoker
Future Models
19
May 30, 2022 11:48 AM
reachout
General Tech Questions
38
Jun 27, 2020 12:35 AM
SuicidalG37SGuy
Sep 10, 2015 06:01 AM
reachout
Sep 8, 2015 10:34 AM
