Help P0171 and p0300 code on g37
Old Nov 13, 2022 | 03:34 PM
RickyPavon12's Avatar
RickyPavon12
What’s good, this my first time posting because I have an issue with my G. This morning I had 2 codes pop up, the 171 being bank 1 running lean and the 300 being random multiple missfires detected. My CEL was also blinking.
Only modifications done to my G is an exhaust cutout at the end of the Y pipe. I checked all fluids and hoses and everything was connected, I checked both spark plugs and coil packs and they all checked out. No fuel is leaking from anywhere besides the exhaust cutout.
When idling, she would run at around 1k rpm’s and I could hear a single misfire every couple of minutes. I cleared both codes and closed the cutout and it returned to an idle of around 700rpms.
i don’t really know what the issue is, any input would be greatly appreciated. My only guesses are that there’s not enough backpressure from the cutout or I’m having problems with my injectors?
thank you
Old Jul 13, 2025 | 08:04 PM
bmo's Avatar
bmo
I got this exact same issue right now and im wanting to see if someone had a solution but no luck. How has yours been since? did you fix it?
Old Jul 14, 2025 | 02:24 AM
Mickael's Avatar
Mickael
Have you try to find any air leak ?
Zachdeg
Jul 31, 2021 07:46 PM
Mitch355277
Jan 16, 2021 04:59 PM
Acftconsultant
Jul 12, 2019 03:44 PM
Huaniitoo
Jun 24, 2018 06:20 PM
