High power on g37x sedan
Old Jul 25, 2023 | 05:12 PM
BillyTheMan's Avatar
BillyTheMan
I had asked this question about the q60 and after dropping and building my transmission I've been thinking about how far i could go with this car. As i had mentioned on the thread about the q60 I'm a fan of awd for high power because it makes it makes the car more usable and easier to handle. Awd can pose a bit of an issue with high power on these cars because there's not as much support for the drivetrain as rwd. I know i can always swap in vr30 transmission if mine can't handle it, what about the driveshaft and axles? If i end up going all the way with a built engine i want around 600 whp, 550 would be ok though. I figured on going the supercharger route since there's not really any awd twin turbo options for the g, either the topgunz kit or the new z1 kit, by the time i can afford it it should be released.
Old Jul 25, 2023 | 06:42 PM
Selym's Avatar
Selym
I wonder how overbuilt the drivetrain components are. The transmission, transfer case, driveshafts, differentials, and CV shafts need to reliably hold up to an engine putting out 269 lb-ft of torque. From a financial point of view, it doesn't make sense to overbuild by that much. Then again, maybe Nissan spec'ed the same components for the G that were used on models with higher torque output, e.g. the V8-based M and Q70 models.
Old Jul 25, 2023 | 07:45 PM
BillyTheMan
I know the transmissions on the v8 cars was a different 7 speed, re7r10b vs re7r10a. I've heard the axles and driveshaft are good for around 500 hp, I'd imagine rwd axles might fit the back so thats covered but I'm worried flooring it from a stop (which i think is the funnest part of awd) would possibly snap a front axle at that power. Haven't really found any front axle upgrades at all. Same with the driveshaft, no stronger awd driveshafts. There's been a few threads on here about it but the idea seems to have been abandoned.
Old Jul 25, 2023 | 08:15 PM
ILM-NC G37S's Avatar
ILM-NC G37S
Just throwing this out there, but how compatible are the drive train components from the R35? I mean, DCT aside, the AWD is the same system.
Old Jul 25, 2023 | 09:40 PM
BillyTheMan
Never thought about that. I think the gtr awd is full time awd vs the front wheel assist on the g37. I could be wrong though.
Old Jul 26, 2023 | 10:45 AM
BillyTheMan
I emailed z1 about the front cv joints, they said i should be ok but may want to replace them before i get the supercharger in case they're worn out.
Superman_G37S
16
Feb 8, 2024 10:45 PM
nonlinearedits
Oct 18, 2023 12:03 PM
14Q60awdSPORT
Nov 26, 2022 09:55 PM
Mojo_Dp
Jul 20, 2022 08:14 PM
Invisibra
Jun 20, 2009 01:06 AM
