Replacement Vacuum Line
Old Nov 24, 2022 | 08:50 PM
G37xMN's Avatar
G37xMN
Looking to add a T for a BOV and lost this elbow shaped vacuum line. Anybody able to find a part number for this so I can get a new one?
Old Nov 25, 2022 | 10:53 AM
BULL's Avatar
BULL
Moderador
Something to keep in mind.
Most folks who go Forced induction get rid of evap controls being that most use these connectors for E85 and boost controller via ECUTEK and if Boost control and e85 content sensor is something you have or are planning to install then you wont be using the metal line.
Either way, there is no part number that will help you since what you need is a T fitting with two small pieces of hose (not OEM).
What I'm recommending is another space giving solution only if you have ECUTEK and are planning on installing these sensors.
PS: evap codes will need to be turned off via programming and converted digitally to E85 and Boost control
Good luck.
kdawg8526
Intake and Exhaust
Jan 25, 2019 01:57 AM
JEBperformance
Brakes/Suspension
30
Apr 2, 2012 11:29 PM
CharlieMac646
Dec 10, 2011 09:59 AM
