Shifter assembly replacement
Old Jul 8, 2015 | 03:50 PM
frank4550's Avatar
frank4550
HI!
I have an issue with my G37S 2010 not always shifting in DS mode. I ordered another complete shifter assembly. Is it a big job to do? Do I need a lift to go under the car to do the job?
Thanks
Old Jul 9, 2015 | 01:37 PM
terribleone's Avatar
terribleone
It is not a big job at all. You will have to remove the shifter head so that you can take the trim pieces off. The trim pieces all snap on and off so that is easy. The shiftier assembly is held down by 4 bolts. I was able to get to the bottom of the assembly just by jacking the drivers side. Use the service manuals online to look up the blown up view Index of /FSM/G37/Coupe/2010
Old Jul 9, 2015 | 05:18 PM
johnnyn's Avatar
johnnyn
I had the same problem. When I'm shifting in ds, the car would go back to D by itself.
I took the to the dealership and they replaced it free because I had extended warranty on the car
beng37s
Intake and Exhaust
Sep 19, 2015 01:32 PM
VIVID
Sep 14, 2015 03:31 PM
SuicidalG37SGuy
Sep 10, 2015 06:01 AM
joshferbs
Sep 9, 2015 08:53 PM
Falker11
