Seized rear wheels/ radiator cooling fan
Old Jun 22, 2015 | 11:46 PM
blkceaser's Avatar
blkceaser
Hello everyone, really need some help. I recently bought a car that was flooded and began to work on it. I got the motor, transmission, starter, battery, BCM, ECU, and IPDM. there are two issue that I am having, the radiator cooling fan win not come on and the rear wheels are seized. The rear differential has been drained and cleaned and properly dried before filling again and they actually got it un seized but it has seized again. Does anyone know what could be causing these issues and can give me some insight on how to fix it???
Old Jun 23, 2015 | 12:40 AM
RadioFlyer's Avatar
RadioFlyer
Did they set the lash properly when they reassembled the rear end? Maybe it's locking up because the ring and pinion are too tight.
Old Jun 24, 2015 | 07:01 PM
blkceaser's Avatar
blkceaser
I'm not sure of what all they did when reassembling. I was thinking it could be the wheel bearings as well being that the car was a flood car
Old Jun 25, 2015 | 06:55 AM
telcoman's Avatar
telcoman
Rust and corrosion!
In addition to replacing or rebuilding parts, you may also need a wiring harness depending on how deep the flooding was.
If you are ever involved in an accident with a salvage vehicle you should check carefully with your insurance company and read the fine print as they may refuse to cover you. You could end up being sued for operating an unsafe vehicle that should only have been used for parts.
Good luck
Telcoman
Old Jun 26, 2015 | 12:09 AM
blkceaser's Avatar
blkceaser
Seazed rear wheels/ radiaator cooling fan
Originally Posted by telcoman
Rust and corrosion!
Good luck
Telcoman
Thanks for the info, I had the wiring harness replaced as well since the carpet was being replaced along with some other things. I will be checking to see if the rear wheel bearings need to be replaced this weekend ( wich I'm sure that may be the issue ) so thanks again
Kojack
Dec 15, 2015 07:03 PM
JSolo
Sep 28, 2015 02:09 PM
Wicked-G
Aug 25, 2015 11:21 AM
