OMG....did I just scarf my G37?
Old Jun 29, 2015 | 11:40 PM
MOB's Avatar
MOB
Ok, freaking out a bit. Was fairly active on the boards in years past & went dark....life happens & dialed it back. But holy crap I could sure use some help. I've got an 09 G37s sedan that's basically stock except for some suspensions stuff. 144K issue-free miles & "fairly" consistent with oil changes always with P ultra or P platinum. I don't abuse my ride, but I do drive it. Today, I was driving & stepped on it to make a pass.....redlined it. After it went into third, it sputtered, lost power, and turned on a pretty hearty knocking noise. I was two blocks from home & limped it to the driveway. Checked oil....down at the very bottom of the stick. Panicked. Added a quart. Started it hoping she was ok. No dice. Knocking like a hammer from the inside out. Am I smoked?
Old Jun 30, 2015 | 01:02 AM
MOB's Avatar
MOB
Took a vid with the hood up....how do I post it?
Old Jun 30, 2015 | 08:58 AM
i heart ricers's Avatar
i heart ricers
are you a diyer ? if not take it to the professionals
144k and no oil ya ur in trouble
Old Jun 30, 2015 | 09:10 AM
MOB's Avatar
MOB
Heres a quick vid. Got it off the road within a half mile. Gotta get it towed somewhere for a look. My daily driver. Am I in trouble, as in, catastrophic/replacement....or repairable? & never had a low oil warning light. I'm gonna throw up.
Old Jun 30, 2015 | 09:40 AM
micafd3s's Avatar
micafd3s
would have said you just needed valve adjustments and was expecting ticking noises..
but after seeing your vid... sounds like rod bearing..
Old Jun 30, 2015 | 10:01 AM
MOB's Avatar
MOB
Rod bearing = screwed???
Old Jun 30, 2015 | 10:08 AM
micafd3s's Avatar
micafd3s
have someone check to see how much damage was done.. that knock sounds substantial.. im guessin you require an overhaul considering you dont know what else was damaged from the lack of lube.. have you noticed any leaks after the last change.. do you do your own changes..
Old Jun 30, 2015 | 10:26 AM
MOB's Avatar
MOB
Nope, never ever any leaks of any kind. Fluids always changed at infiniti's quick serve lube shop. Job change last year reduced my driving by more than 80%, so it's been a while since last oil change & have never noticed oil consumption being an issue since owning the car new. All the more reason I was shocked to find the oil so low when this happened. Gotta get it to a shop...but that's scary with the vultures looking to take advantage of someone's misfortune. Anyone in Sacramento with a recommendation for an honest mechanic who won't screw me? Definitely hesitant to inquire with the local Infiniti dealer. Dammit.
Old Jun 30, 2015 | 10:34 AM
TheLocNar's Avatar
TheLocNar
Get it towed to a shop. Don't be driving that anymore until you get it looked at. Good luck!
Old Jun 30, 2015 | 10:43 AM
MOB's Avatar
MOB
Definitely not even gonna start it. Makes me sick.
Old Jun 30, 2015 | 10:53 AM
i heart ricers
by reading your posts im guessing youre not the kind of guy who can dig around and look yourself so tow it and stop starting it and making videos
Old Jun 30, 2015 | 11:15 AM
MOB's Avatar
MOB
Nope....this is certainly out of my league. Took the vid immediately as I parked it after this happened. Haven't started it since & won't.
Old Jun 30, 2015 | 11:36 AM
micafd3s's Avatar
micafd3s
has she been smoking at all... wonder where the oil consumption was...
always make it a habit to check oil level.. even right after change since you didn't do it..
Old Jun 30, 2015 | 11:40 AM
MOB's Avatar
MOB
Nope. Never emitted any smoke whatsoever. Always a clean & smooth running car.....until this. Sucks, just a few days ago I tried to get in for an oil change & ran out of time. Even while driving yesterday was thinking "gotta get it in...gotta get it in" & bam.
Old Jun 30, 2015 | 11:42 AM
micafd3s's Avatar
micafd3s
one thing ive learned at this age... always listen to your conscience..
look at it as justification for a nice build mob....
