clutch pedal looses pressure ( new HD zspeed slave )
Old Aug 8, 2015 | 10:33 PM
slotterjordan's Avatar
slotterjordan
I just had a new dual mass oem flywheel. Jwt clutch kit. And a heavy duty slave cylinder put in. Also my master cylinder got a rebuild kit. It's only 3 months old so I didn't replace it. And my pedal looses half its pressure and I have to pump it up and it will loose pressure again after pressing it down again . so it might have air in the system. Any input would be appreciative! Thanks
Old Aug 8, 2015 | 10:57 PM
JSolo's Avatar
JSolo
Just say no!!!!!
Did you have a good pedal once it was bled?
Why did a 3 month old MC need a rebuild? Maybe it wasn't rebuilt correctly.
Old Aug 8, 2015 | 11:00 PM
slotterjordan
Well it said to change your master when putting in the heavy duty slave cylinder. And I replaced it brand new 3 months ago. And my mechanic did it all so I wasn't there. And when I picked up the car it seemed okay. But the next day I noticed it getting flimsier at the top of the pedal and my engagement slowly going down. And the rebuild is simply a spring and seal. Can't be that hard.
Old Aug 8, 2015 | 11:01 PM
slotterjordan
Old Aug 8, 2015 | 11:25 PM
JSolo's Avatar
JSolo
Just say no!!!!!
New parts usually come with a warranty, typically 12 months/12K miles. Who supplied the part?
Could be air in the line or a faulty MC.
Old Aug 8, 2015 | 11:29 PM
slotterjordan
Rock auto. Just an oem one. But its always worked. So idk. Could have air . apparently the HD slaves are hard to bleed. And you have to bleed it several times. Idk what my mechanic did so
Old Aug 8, 2015 | 11:46 PM
JSolo's Avatar
JSolo
Just say no!!!!!
If it didn't come from the dealer it's not an OEM part. It may fit like an oem part, but not necessary function.
Certain parts you just don't want to use reman or third party. I remember the optispark unit in the camaro. After 2 non OE parts stranding me, I paid a bit more and with with a gm part. Never had a problem again.
Old Aug 9, 2015 | 05:09 PM
telcoman's Avatar
telcoman
Originally Posted by slotterjordan
Rock auto.
When you buy cheap you'll usually end up buying twice.
When I had a CSC problem on my previous 06 G35 the dealer replaced it under warranty and I never had another problem. Traded it in at 171796 miles
Telcoman
Old Aug 10, 2015 | 12:17 AM
sLADe781's Avatar
sLADe781
If you're not losing any fluid then your master cylinder is probably the problem. I had a similar issue earlier this year where I kept losing pressure and had to pump it like 50 times to get pressure back but the following day, the pressure would be gone again. It turned out to be the master cylinder and ever since I replaced it, everything has been good. My thread is here.
I would recommend that you first re-bleed the system to ensure there's no air in the system. The best way to do this is to gravity bleed it. If the symptoms persist after verifying that you've removed the air from the system, I would replace the master cylinder with a new one vs a rebuild kit. If for some reason you decide to go with a rebuild kit again (really not advisable), I would at least buy an OEM kit just to remove all variables.
Good luck and let us know what happens.
37
Oct 17, 2020 11:12 AM
linvbro
Aug 22, 2016 01:25 PM
stevo4756
Oct 9, 2015 01:54 AM
m3clubracer
Sep 28, 2015 03:45 PM
r0cketm0nkey
Sep 27, 2015 01:34 PM
