Help Chattering/Rattling Noise sitting in Neutral
Old Aug 21, 2010 | 05:17 AM
pinyapple5's Avatar
pinyapple5
I've got a slight issue that may or may not be something that's just characteristic of the engine/transmission or something that I may just need to bring to the attention of the dealership to have rectified.
I have a 2010 G37S Sedan 6-speed manual.
I've had manuals all my life and this is the first one that makes this chattering noise while sitting at an idle. I notice the noise most prominently when sitting in my garage after starting the engine or pulling in about to turn it off when the car is in neutral w/ no clutch application.
It sounds like the clutch itself is not fully disengaged or something is going on w/ the pressure plate/flywheel contact. As soon as I step on the clutch all the way the noise is gone. As soon as I let go of the clutch it comes back. It has been doing this since 22miles on the car when I purchased it. THe car now has approximately 1300 miles and it is doing it still, even worse than before I might add.
Any take on this issue ladies n gents? I know there aren't too many 6-speed manual guys out there but hopefully SOMEone has seen this issue.
Old Aug 21, 2010 | 10:00 AM
Kidcane's Avatar
Kidcane
Florida G Club
Unfortunately it is not considered and "issue" as its common with the G35 and G37 manual transmissions. Although some people were much worse than others and did have some actual problems with the transmission and were able to have it fixed or replaced. Do so searching, there are several threads.
Old Aug 21, 2010 | 12:28 PM
G Nack 37s's Avatar
G Nack 37s
The only chattering I get is from my cats and is common with the manual tranny in our G.
Old Aug 21, 2010 | 12:35 PM
Weiboy718's Avatar
Weiboy718
try putting on a Lightweight Flywheel. that's chattering hahaha.
Old Aug 21, 2010 | 12:37 PM
G Nack 37s's Avatar
G Nack 37s
^Lol......
Old Aug 21, 2010 | 02:19 PM
pinyapple5's Avatar
pinyapple5
So I suppose it's normal then :/ great job Infiniti.
Old Aug 21, 2010 | 03:13 PM
The "cement mixer" sound you are talking about is unfortunately considered normal on our cars. It's a throwout bearing issue. I believe that one or 2 people have had it eliminated by replacing the throwout bearing. I don't think this was covered under warranty but I'm not sure.
37
Oct 17, 2020 11:12 AM
fuzzed
Aug 21, 2020 09:35 AM
Rybitron
Nov 18, 2015 03:11 PM
si_driver
Oct 1, 2015 09:53 AM
MrRiv
Sep 29, 2015 04:59 PM
