Help Twin turbo for 350z hr for g37s
Old Mar 17, 2013 | 02:44 PM
lilvi3tboyzz's Avatar
lilvi3tboyzz
i was wondering if the 20g greedy twin turbo kit for 07 08 hr 350z motor, will fit a g37 AT ? without any modification ?
Old Mar 17, 2013 | 03:34 PM
G37HKS's Avatar
G37HKS
call the company
Old Mar 17, 2013 | 06:55 PM
SharpByCoop's Avatar
SharpByCoop
A. More than likely.
B. Probably not.
Depending on pricing it's probably worth the troubles, but I would doubt it's a bolt on.
If Greddy answers your call, of course, they'd know best. Unless someone here has done this EXACT same conversion you will only get speculators. Like me.
Coop
Old Mar 18, 2013 | 02:16 AM
dimsler's Avatar
dimsler
The biggest concern would be the kit fitting around that fat *** 7speed. Otherwise it should be a pretty direct bolt-on, aside for hacking up the FMIC in with different piping.
You'd have to be able to test fit the exhaust manis, turbos, and downpipes, and see if they clear the trans.
Old Mar 18, 2013 | 03:18 AM
da mayor's Avatar
da mayor
Pipes around the steering might be modified
Old Jul 20, 2014 | 11:51 PM
Skyrhino's Avatar
Skyrhino
For the record, I can tell you that my '09 G37X required MASSIVE modification, to include notching and welding the frame, to fit the 350Z GReddy TT kit. My X has more space constraints obviously, due to the AWD. However, I'd be very very cautious before you commit to this kit. It did not work smoothly or cheaply for me! Word to the wise.
Old Jul 21, 2014 | 01:03 AM
Skyrhino's Avatar
Skyrhino
I should point out that my GReddy kit was for the '03-04 350Z, with TD-18's. Cheers.
Old Jul 22, 2014 | 10:06 AM
ANMVQ's Avatar
ANMVQ
So you bought a kit for a 03-04 350Z and it bolted to you X G37?
Old Sep 9, 2014 | 11:49 AM
Skyrhino's Avatar
Skyrhino
Mmmmmmmmmmmm, yes. And I don't recommend it because of all the fabrication that's required for the install. On the plus side though, the car is fun to drive. With the stock Greddy wastegates only giving me ~6psi, the car is making about 425 HP at the crank and is fairly entertaining to drive. Planning to increase the boost in the future, along with suspension and transmission upgrades. Cheers.
35Sport
Feb 2, 2017 11:32 AM
G37 IPL Bryan
Sep 15, 2015 04:40 PM
bkouba88
16
Aug 21, 2015 12:44 AM
abretz89
Aug 20, 2015 11:58 PM
nethole
Aug 12, 2015 04:08 PM
