white smoke
Old Apr 12, 2013 | 06:15 AM
jusrushem's Avatar
jusrushem
white smoke
Just curious. i'm looking atg a 2010 g37s coupe, with 29,000 miles. when i start it up, white smoke comes out like a cloud. if you rev the motor up, it comes out again. any idea what that is? i'm thinking head gasket. any input would be great. thanks
Old Apr 12, 2013 | 08:18 AM
jaykellogg's Avatar
jaykellogg
White smoke is usually water in the exhaust. The car should be covered by factory warranty, but if there is any question I would leave it. I would absolutely call in the VIN to ensure that the warranty is still in effect.
Old Apr 12, 2013 | 12:15 PM
JSolo's Avatar
JSolo
Just say no!!!!!
What does the smoke smell like? Is it sweet?
Old Apr 12, 2013 | 12:41 PM
mr_nlu's Avatar
mr_nlu
no matter what the issue is, i would walk away from it and look at another car. its not worth the trouble buying a used car that was someone else's problem
Old Apr 12, 2013 | 01:18 PM
SwissCheeseHead's Avatar
SwissCheeseHead
What's the ambient temp? It could be water vapor in the exhaust or it could be burning coolant as Jsolo is referring to which is sweet smelling. If it's colder outside, the water vapor will be more noticeable than if it's warmer. If it's warm and you're still seeing white smoke, waft some of it for the scent. Any sweet smelling, walk away. Most likely it's just vapor.
Old Apr 12, 2013 | 01:58 PM
BLAIR'N G372012's Avatar
BLAIR'N G372012
I agree with Swiss & Jsolo...
The Scent of coolant is obvious. Sweet smell and its a steady vapor, not sure of your location like Swiss said but sounds like water vapor.
29k is not a lot of miles yet it being a 10 sounds like a Lease return...
Old Apr 13, 2013 | 03:04 AM
jusrushem's Avatar
jusrushem
thanks
Thanks guys. BMW of honolulu took it to infiniti to get it checked out. The smoke comes out when i first started it, & when i reved it up. ill post a video of me revving it up. Thanks guys
Old Apr 13, 2013 | 06:29 AM
jusrushem's Avatar
jusrushem
Old Apr 17, 2013 | 02:07 PM
Glenn2008's Avatar
Glenn2008
What did Infiniti find? I have the same problem on the first start of the day for about 10 seconds, after that it goes away and on subsequent starts nothing.
Old Apr 17, 2013 | 03:44 PM
canucklehead's Avatar
canucklehead
guys, it's just vapour being pushed through the system. all cars with internal combustion engines produce it. as was said above, ambient temps affect how much, or for how long, ""white smoke" is visible upon cold start-ups or revving of the engine. once the engine has warmed up there should be little to no "smoke" at warmer climates.
this is a non-issue. coolant leaks (head gasket issue) are much more obvious, and will not go away after a few seconds upon cold start up.
Old Apr 17, 2013 | 05:28 PM
Glenn2008's Avatar
Glenn2008
Thanks for posting up Canucklehead! I didn't think it was a problem, but when I seen the concern, I thought that I may have a valve seal problem.
Old Apr 17, 2013 | 05:36 PM
DaCePtak0n's Avatar
DaCePtak0n
its the hookah option installed lol..JK
Old Apr 18, 2013 | 04:14 PM
Mayu's Avatar
Mayu
^^ LOL
To the OP - how thick is the "smoke"? Does is have the density of your breath on a semi-cold day (nearly transparent) OR cloudy (thick and opaque). The latter would be reason to walk away.
Mine has done this since day 1 and is obviously water. I say this because, I can see it settle on the bumper above and almost immediately evaporates. It also smells like "exhaust"... at least, for the brief time I was concious while trying to sniff it.
GL!
Old Apr 21, 2013 | 05:11 AM
jusrushem's Avatar
jusrushem
well, i called infiniti, & they said that the head gasket was blown. needs major over haul on the motor. this smoke was consistent. fyi..
Old Apr 21, 2013 | 08:54 AM
jaykellogg's Avatar
jaykellogg
I would cross that one off the list. Even after it was repaired.
