Matic S Alternative
Old Feb 14, 2016 | 10:46 AM
Snipres's Avatar
Snipres
Matic S Alternative
Going to replace the ATF in my g37. Was originally going to do AMSOIL but i seen some members run valveoline maxlife atf as well.
Any other suggestions?
I like how the valeoline is almost half the price as the amsoil
Old Feb 14, 2016 | 10:55 AM
Selym's Avatar
Selym
Why not use what Nissan specifies (Matic S)?
Old Feb 15, 2016 | 05:22 PM
I looked around when replacing my ATF and the only over the counter ATF that had the Matic S compatibility on the label (that I found) was the Valvoline. It's performed well so far
Old Feb 15, 2016 | 11:29 PM
PearlPereZ's Avatar
PearlPereZ
I used Valvoline Atf on my g35, and i never had any tranny issues. I think im going to do the same for my g37.
Old Feb 16, 2016 | 05:24 AM
Snipres's Avatar
Snipres
Walmart has a great deal right now on the valvoline. THink im going to pick up (3) 1-Gallon jugs
Valvoline MaxLife High Mileage DEX/MERC Automatic Transmission Fluid 1 Gallon - Walmart.com
Old Feb 18, 2016 | 09:10 PM
If you do it as per Davisons DIY I'd get 4 gallons
https://www.myg37.com/forums/d-i-y-i...ml#post3923814
Old Feb 18, 2016 | 10:25 PM
Victory's Avatar
Victory
For a savings of $20 or so every 80,000 miles...I'll stick with Matic S. ATF is the only fluid if find cars to be picky about.
Old Feb 20, 2016 | 11:06 AM
Snipres's Avatar
Snipres
I'm sure nissan doesn't make their own ATF tho.
Old Feb 20, 2016 | 11:19 AM
Selym's Avatar
Selym
They don't make the transmission, either. Jatco does, and Jatco specifies the properties of the fluid.
Unless you're absolutely certain Valvoline and Amsoil meet their specs, I'd stick with Matic S.
What is the advantage of not using Matic S?
Old Feb 20, 2016 | 03:56 PM
Like I mentioned previously, I looked around quite a bit and the Max Life was the only one I found that listed Matic S on their recommended application chart. I seriously doubt they would put it out there if it didn't meet spec, especially in this litigious society
desertmike680
20
Mar 24, 2022 12:13 PM
StreetStandard
Wheel & Tires
98
Aug 30, 2016 01:11 PM
Yohan1995
NorthEast
Feb 26, 2016 10:01 PM
Ihtbealexxx
Intake and Exhaust
Feb 14, 2016 12:39 PM
akiradavis
Feb 10, 2016 05:36 PM
