Auto jerks forward when coming to a stop?
Old Mar 24, 2016 | 06:14 PM
justinc7100's Avatar
justinc7100
What's up guys, I have noticed recently that my car jerks forward a bit when coming to a stop sometimes. The car shifts fine but it's just when I come to a complete stop and the car downshifts from 2nd to 1st. When this happens the rpms are normal so I have no idea what it could be. I have 2009 g37x with 108k miles and I am thinking it is the tranny fluid needing the be flushed.
I don't want to do it myself and am currently saving up to pay for the dealer to do it. Any idea what this could be? Really worried right now that my transmission is going. I also noticed that when I rev the engine only to 2k in idle, the rpms stay at 2k for a couple seconds then drop back down normally. Any help is greatly appreciated, I am very worried about about the transmission. I have new spark plugs and I cleaned the throttle body and also just received the ecm update from Infiniti. Really hoping it's just a tranny fluid flush. Going to Infiniti Tuesday morning. Thanks!
Old Mar 24, 2016 | 06:38 PM
e3phung's Avatar
e3phung
it does sound like there is some slipping from 2nd to first, maybe the rpm are dropping to fast from 2nd to 1st which is causing the jerk. Could be tricky problem, a flush may or may not help. Hopefully someone on this forum has experience this problem.
Old Mar 24, 2016 | 06:44 PM
justinc7100
Thanks for the reply. The car was just at Infiniti for rough downshifting and they applied the ecm update and said that should take care of it. I am hoping it is really nothing, the tech who drove the car around didn't even mention it so maybe it's not as bad as I think. I'm going to show them Tuesday morning.
Old Mar 24, 2016 | 08:08 PM
HoldmyMouse's Avatar
HoldmyMouse
When you go back, remember to request the tech to ride along while you try to replicate the problem. Often times when you describe to the service rep, they might interpret it differently and the tech will have no clue what you are talking about. Good luck
Old Mar 24, 2016 | 10:36 PM
justinc7100
Yeah that's exactly what I told them I wanted to do thanks for the advice. You don't think the trannys going do you? Apart from this problem it works fine.
Old Mar 27, 2016 | 02:31 AM
kdawg8526's Avatar
kdawg8526
your trannys not going mines been doing that for past 5 years just the rpm dropping too fast from 2nd to 1st
Danjjacob
Aug 14, 2013 11:30 AM
Superteeth
Dec 21, 2012 12:24 PM
FourOneFive
Sep 25, 2011 07:37 PM
joey_v
Sep 6, 2011 06:12 PM
