2011 G37x Sedan transmission swap
Old Mar 30, 2016 | 08:44 AM
WTN's Avatar
WTN
Picked up a G37x for a good price with a blown transmission. Was told the wrong tranny fluid may have been used and given the condition of the car there are indications it wasn't driven too rough.
Anyway given the price for a new transmission at $9350 this has me going to scavenge one from a junkyard. Some research leads me to believe I have a JATCO JR710E transmission.
Is this the same transmission as the RWD with the transfer case bolted to it or considered one integral combined piece? Also what range of years should I look for 08-14 ? for the tranny to bolt on and fit?
Thanks,
-Bill
Old Mar 31, 2016 | 09:30 PM
TexVol's Avatar
TexVol
Try here.
Level 10 TRANSMISSION
Old Mar 31, 2016 | 11:33 PM
Upscale Speed's Avatar
Upscale Speed
Level 10 FTW. Get it done right and never worry again.
Old Apr 1, 2016 | 12:21 AM
G37xsfun's Avatar
G37xsfun
Check here: http://car-part.com/
Old Apr 1, 2016 | 08:27 AM
WTN's Avatar
WTN
Tempting for sure but I have to control myself. Knowing something could break if I get too rough keeps me tame.
Old Apr 1, 2016 | 08:52 AM
WTN's Avatar
WTN
Nice having access to a lift. I don't think I want to start the engine cold and pump all the old fluid out of the cooler line before it heats up like I used to.
Seems the preferred method here is to warm it up a bit and perform measured drains and refills and repeat. Makes sense these days given the nooks and crannies.
Redline D6 ATF seems to be the consensus for the transmission and transfer case and going to drain and pump in motul 75w-90 for the differentials. I have Mobil 1 0w-40 in to run the motor.
Old Apr 2, 2016 | 02:16 AM
msonbolg37x's Avatar
msonbolg37x
getting a bullet proof transmission from level 10 will set you back less than 6k installed which blows almost 10k for a stock transmission out of the water
BrianG314
May 29, 2016 07:40 PM
tite_tite
General Tech Questions
Mar 27, 2016 01:47 PM
Baby Jumpman
Mar 24, 2016 01:22 PM
kenbulmer
Mar 12, 2016 05:36 PM
