Amsoil Severe Gear 75w-90 diff fluid change
Old Feb 25, 2016 | 02:33 PM
zib331's Avatar
zib331
Came across a good deal for 2 quarts of Amsoil Severe Gear 75w-90 diff fluid. Just wondering if anyone has used this weight and brand for their differentials.
I have a 2008 g37 journey that I just recently purchased. I got it with 56k miles (now has 62k miles) so I just wanted to take care of some basic maintenance.
Just not sure if for some reason these cars require a specific diff fluid or if the Amsoil 75w-90 will suffice...
Old Feb 25, 2016 | 02:43 PM
jfisher's Avatar
jfisher
That is what is recommended by Amsoil for our cars. I'm about to purchase the same stuff for my rear diff.
Old Feb 25, 2016 | 02:49 PM
zib331's Avatar
zib331
Do you think going with Amsoil recommeded tranny fluid would be good too or for the trans should we only use the nissan matic stuff?
Old Feb 25, 2016 | 02:54 PM
chuckie311's Avatar
chuckie311
Drop A Gear and Disappear
i use Amsoil for everything.. and yes im going to use when i do my transmission flush later this year
Old Feb 25, 2016 | 03:21 PM
xnick101's Avatar
xnick101
Has anyone had any issues after using Amsoil in their diff? I am soon going to change mine too. Was debating between OEM and Amsoil.
Old Feb 25, 2016 | 04:35 PM
m3clubracer's Avatar
m3clubracer
Like Chuckie I use in everything.
Old Feb 25, 2016 | 04:54 PM
SlateBlue G's Avatar
SlateBlue G
I've changed amsoil on my manual trans and diff at 100k. At 135k with no problems.
Check the DIY forum for the DIYs I posted for transmission and differential oil changes. In stickies.
Old Feb 25, 2016 | 04:59 PM
SlateBlue G
Bringing back memories. you were the first one to post the DIY and used Amsoil so I followed LOL
Old Feb 25, 2016 | 05:27 PM
Surfnazi's Avatar
Surfnazi
Motul works well
Old Feb 25, 2016 | 07:11 PM
chuckie311's Avatar
chuckie311
Have had it in my diff for almost a year 0 issues
Old Feb 26, 2016 | 11:44 AM
zib331's Avatar
zib331
thanks everyone for your feedback.
I'm going to stick with Amsoil for the diff fluid and trans.
I did my first two oil changes with Amsoil 5w-30 and its great stuff. Noticebale difference in valve noise compared to Mobil 1 5w-30.
happy to use all Amsoil for motor oil, trans, and diff!
Old Feb 26, 2016 | 03:42 PM
canucklehead's Avatar
canucklehead
i used amsoil diff as well as gearbox fluid for the previous change. no issues with the diff fluid, and no friction modifier was needed.
at my latest change i went with redline fluids in both the diff and gearbox. i can't tell any difference with the diff (noise and lash is the same) but the gearbox is smoother in cold weather using redline MT fluids. other than that, the amsoil and redline fluids are about the same....from the driver's seat, anyhow.
Old Feb 27, 2016 | 04:35 AM
m3clubracer
When I used Redline in manual trans cars it seems to work more freely cold than any other I have used. However Amsoil thinned within 3-5 min. and was the same.
Old Feb 29, 2016 | 01:46 PM
SlateBlue G
I used amsoil, my buddy used the redline mt-85. results are the same. Only difference I see is on cold starts where redline had more freeplay than amsoil.
