2010 G37 Coupe. Ticking/Clicking noise
Old Feb 23, 2020 | 06:16 PM
ScriptedCoupe's Avatar
ScriptedCoupe
2010 G37x coupe 7AT. So the car was due for an oil change. I noticed there wasn't a lot of oil in the car as I was doing the change. The light for the oil had not come on at all on the dash prior to changing the oil. After i finished and started the car up i noticed it started to make this ticking/rapid clicking noise when I accelerate towards the 2-3k RPM's and also when I let off the gas as well. It doesn't matter which mode I drive it in it still ticks/clicks. The noise sounds like its coming from the engine. More towards the back, closer to the driver side. Any ideas?? big thanks in advanced.
Old Feb 23, 2020 | 06:37 PM
Conboss's Avatar
Conboss
https://imgur.com/a/xdg3zhE
posting this just to see if the noise your hearing is like this. If it is, then it’s your cats.
Old Feb 23, 2020 | 06:57 PM
ScriptedCoupe
It sounds pretty similar. this is what I hear from the inside. I'll definitely look into the Cat first thing in the morning.
File Type: mov
Old Feb 23, 2020 | 07:37 PM
Conboss's Avatar
Conboss
Sadly those weren’t my exact symptoms. I was getting rattling at idle and on decel, I knew my cats were on their way out for the longest time. Definitely check them out though
Old Feb 24, 2020 | 09:00 AM
Surfnazi's Avatar
Surfnazi
Check battery tie down. If you recently replaced it thse tie down might need to be readjusted
bitNine
48
Dec 4, 2019 07:45 AM
angeljr8282
Feb 8, 2014 10:26 AM
mystakin
Oct 5, 2010 11:34 PM
DrJones
17
Jun 19, 2009 12:28 PM
leelijian
Mar 26, 2009 02:35 PM
