G37 rattling noise - help!
Old Apr 1, 2020 | 05:43 PM
Pr0ject37's Avatar
Pr0ject37
Before the car Would not stay started check engine code was the crank shaft I changed the sensor now it starts and run now it’s this rattling sound anyone has an idea what I could be
Old Apr 2, 2020 | 09:33 AM
SonicVQ's Avatar
SonicVQ
I hope I am wrong, but it sound like rod knock.
This is where the big end (lower) part of the connecting rod has too much play and it rattles around the crankshaft.
How was the car running before it wouldn't start?
What mods does it have?
Old Apr 2, 2020 | 09:49 AM
Pr0ject37's Avatar
Pr0ject37
You might be right but before all this happened it was running awesome it has uprev dyno flame map gen 3 intakes and 1320 test pipes
Old Apr 2, 2020 | 10:15 AM
jfridge92's Avatar
jfridge92
Drain the oil into a clean, open drain pan, and let some of the oil filter through a paper towel while it drains. Look for metal sparkles or pieces in the oil. If any's present, that motor is done. If not, you could try checking the flywheel bolts or torque converter bolts if you're an AT. If those bolts start to back out, they can sound a lot like rod knock too. The fact you have test pipes rules out it being converter rattle, but that definitely does not sound good.
Infiniterian
Nov 5, 2019 10:42 AM
Eugenius
14
Oct 15, 2019 02:56 PM
ko3r
Intake and Exhaust
40
Apr 18, 2019 03:24 PM
RQ1986
General Tech Questions
Apr 8, 2015 05:17 PM
djsk
Feb 23, 2010 10:12 AM
