G25 2012 gcc
Old Feb 23, 2020 | 03:20 PM
G25s's Avatar
G25s
G25 2012 gcc
Greetings, my brothers, I have a 2012 model G25, during this time I faced a problem with the car’s temperature when using the car and the air conditioner. The car does not heat up a little, but when the air conditioner is turned on, the temperature returns to normal, but when the car is pedaled it rises slightly with the air conditioner turned on, so what is this problem! For information, you have changed fans and changed thermostats, so what do you think is the problem?
Old Feb 24, 2020 | 09:01 AM
Surfnazi's Avatar
Surfnazi
Check belt and tensioner also if you recently changed rad fluid might need a burping
Old Mar 8, 2020 | 01:46 AM
G25s's Avatar
G25s
Arrow
I CHANGE
1- SONSER TEMP ( NEW )
2- RADITOR ( NEW )
3- CONDECSOR FOR A/C ( NEW )
4- THORMOSTAT ( NEW )
5- 2 FAN AND OEM Cooling Fan Control Module ( USE )
Old Mar 9, 2020 | 07:52 PM
Conboss's Avatar
Conboss
Sounds like a potential air bubble. Make sure to bleed and burp the system as best you can
Richey111
Sep 19, 2021 05:46 PM
G25s
General Tech Questions
Aug 22, 2019 10:50 AM
hkbazzi
Sep 5, 2018 03:54 PM
defektion
Jan 15, 2018 11:10 PM
netwiser
Jan 11, 2014 11:10 AM
