Help Cylinder 6 Misfire
Old Apr 3, 2020 | 09:08 AM
Chris Dix's Avatar
Chris Dix
Cylinder 6 Misfire
The other day I was driving and started to notice a tap from the engine and car running rough. I got home and scanned it and have a p0300 and a p0306. The misfire counter on cylinder 6 is bad with residual misfires on cylinder 4 and 5 as well but not too bad. I have replaced the plugs, swapped coils and injectors, replaced fuel dampers, replaced valve cover gaskets as well as the lower and upper intake gaskets. I have ran a gas treatment through incase it was bad gas and also did an oil change with ester oil. Also have cleaned the mass airflow sensors and throttle bodies but I am still getting a bad misfire from cylinder 6 that even causes the CEL to flash. I am going to be doing a compression test on it this weekend to test that but does anyone else have any ideas what it may be? It's a 2012 G37x with 104k on it. Any help would be appreciated. Thank you.
Old Apr 3, 2020 | 03:25 PM
Surfnazi's Avatar
Surfnazi
Maybe bad harness
Old Apr 3, 2020 | 03:27 PM
Chris Dix's Avatar
Chris Dix
Originally Posted by Surfnazi
Maybe bad harness
I have checked the harness all along the back of the motor and all the grounds and I dont see any damaged wires or wires chewed by any kind of rodents
Old Apr 3, 2020 | 06:06 PM
Conboss's Avatar
Conboss
I don’t know how our cars handled it but Honda’s would flash the CEL if it’s pre-igniting. Just something I thought of
Old Apr 3, 2020 | 08:15 PM
SonicVQ's Avatar
SonicVQ
A flashing CEL simply means a misfire, which you already know.
With all the work done so far, my next step would be to check the fuel pressure. Factory spec is ~51 psi.
Since this engine has a return-less fuel system you will need a fuel tap like this one:
https://cj-motorsports.com/products/fuel-tap-npt-2-bolt
and a 60-100 PSI gauge.
You also might want to have a look at your short/long term fuel trims in the free frame data. If you add the short term and the long term, the result should be between -15 to 15%.
VRedG37s
18
Feb 7, 2025 11:49 PM
soundkillr
25
Feb 1, 2017 01:42 AM
Kaotic Blue
Jan 26, 2016 09:14 AM
InitialDeezNutz
General Tech Questions
Feb 19, 2015 11:43 AM
