Car starts to Stutter at 2200 RPM and wont go higher
Was driving my car earlier and it decided to go limp on me. Car won't go above 2200 RPM, it begins to stutter when I try to accelerate past 2200.
No check engine light came on or anything else. I did the IDLE relearn when I got home and it can finally go past 2200 RPM. What could be the cause of it doing that to begin with?
No code, it was actually snowing when this happened! I slipped for a second and the stutter started. Never had the stutter ever since I reset the throttle bodies.
Hey everyone had the same thing happen again this year with the car going into limp mode. It only occurs when its snowing outside. A code popped up reading P0101. Cleaned out my MAF sensors and hasn't happened again since.
Has anyone else have this issue happen to them?
yup I’ve had the same thing happen whe. It’s snowing/blowing snow 3 times in 2 months. Haven’t figured anything out yet.
what’s the weather like where you are?? Loose blowing snow by chance?
check your air filters good chance they are out of shape on the sides and letting snow in hitting the MAF sensors. Happened to me everytime it was blowing snow out. Just figured this out yesterday. The filters get damp/old and the motor tries to pull air around them. I had gaps on the sides as well It was very stiff in the cold and would not spring back at all.
Adam Abdellatif
Aug 1, 2020 01:08 AM
Starbuck393
Oct 4, 2019 12:48 PM
Alagator28
17
Jun 8, 2018 02:51 PM
adlee3
Mar 20, 2013 07:23 PM
