Help Orange puddle under car
Old Jan 11, 2020 | 08:39 PM
spankgo's Avatar
spankgo
Hello,
Found an orange-ish puddle on the asphalt under the hood of my 2010 G37x. Read online it could be antifreeze. I wanted to see if anyone here has
had a similar issue, and what your experience was diagnosing and fixing it.
thanks!
Old Jan 11, 2020 | 09:42 PM
Surfnazi's Avatar
Surfnazi
Antifreeze has sweet smell and Nissan fluid is blue. Could be rad fluid or trans fluid which is red but changes color as miles put on it
Old Jan 12, 2020 | 10:36 AM
NealP's Avatar
NealP
Is your washer fluid orange?
Old Jan 12, 2020 | 12:27 PM
Epiphany's Avatar
Epiphany
Open your rad and check your overflow tank to see what colour coolant is in your car. Should be blue or green but may have been replaced with a different one at some point.
Old Jan 13, 2020 | 11:40 PM
crookncastle's Avatar
crookncastle
did someone put dexcrap into your cooling sys? nissan coolant factory fill on these cars is blue. someone may have used the wrong coolant prior and its possible theres a leak now.
Old Jan 24, 2020 | 02:01 PM
Crusher103's Avatar
Crusher103
are you sure that is from your car? move the car and see of that puddle pops back up. I cannot think of an orange fluid in a nissan, that looks more like oil. however from that location it would either be power steering, transmission or coolant leaking. all should be relatively easy to fix just burbing whatever system is leaking would be the PITA.
xceebeex
General Tech Questions
17
Mar 6, 2013 02:41 PM
Infiniti7
Feb 6, 2011 07:39 PM
jarena2104
Sep 11, 2010 12:32 PM
