need some help
Old Mar 5, 2012 | 02:18 PM
unknowndesi's Avatar
unknowndesi
need some help
This morning I cranked up my car and the engine wouldn't turn over all I could hear was the starter motor starting to crank the engine I held down the start button and I could hear The starter motor trying to catch on and crank the engine and it finally did....
Is the starter motor gone? And is it something that's covered under the powertrain or am I just going to have to fix it myself
Old Mar 5, 2012 | 04:04 PM
criledo's Avatar
criledo
Sounds more like a weak battery problem. Besides the starter motor might going out, like you say, also consider that the solenoid might be faulty, no need to change the whole motor. One way or another I seriously doubt this can be related under 'Powertrain".
Old Mar 5, 2012 | 04:10 PM
blindman8858's Avatar
blindman8858
Check your battery levels first. Our cars have had some battery troubles. There is a TSB for the battery, check it out.
BTW, make your self known desi man, I am punjabi, where are you from?
Cobra-2-G's Avatar
Cobra-2-G
Probably battery--is it the original?
Old Mar 5, 2012 | 04:26 PM
DashKid's Avatar
DashKid
Might be the battery. There is a TSB for this issue if your car is still under warranty. What I did was I went to autozone asked to see if I can test out a battery real quick and it turned over fine. If that doesn't work then it can be your starter which would be covered under you're warranty.
Old Mar 6, 2012 | 12:03 AM
unknowndesi
I just bought a red top about 3 months back and I made my own grounding kit... I checked all the solenoids for proper voltage but I think I'll just take it off and rebuild it... Could just be cold Temps here in Toronto... Let's wait till tmrw and if I have to replace the starter I'll def make a DIY
Old Mar 6, 2012 | 10:15 PM
bthe13's Avatar
bthe13
left headlamp wire harness wante for coupe g37
sorry if i posted on the wrong page i am a newbie here or maybe i dont have full access lol but i am looking for the plug that goes into the hid ballast and i also need a rear spoiler preferably in black please
