My G Coupe Sounds Different When Starting Up..
Old Jan 4, 2012 | 07:46 AM
glassjaw047's Avatar
glassjaw047
Past couple of times my G coupe hasn't been as loud on the start up (exhaust noise). Here in NY the weather has got a lot colder in the last couple of days (this morning the car was reading 15 degrees). I mean at like 35-30 degrees It starts up sounding the same. So could this be due to the REALLY cold weather?
Old Jan 4, 2012 | 07:52 AM
Lt8Che's Avatar
Lt8Che
'Cuz Racemod-erator
I know my coupe sounded different when starting up in ND, but that was like -10 - 10 degrees. Cold probably has a lot to do with it.
Old Jan 4, 2012 | 08:57 AM
chilibowl's Avatar
chilibowl
Its definitely the cold. If you start your car, and immediately take off while the engine is still cold... and you floor it (Dont Redline, just 4K RPMs), you will notice the car sounds much meaner and much more different. Once the engine reaches operating temperature, it will go back to sounding "normal" .
Old Jan 4, 2012 | 09:38 AM
SwissCheeseHead's Avatar
SwissCheeseHead
that's odd. It should be louder when its cold than when it's warm...
Old Jan 4, 2012 | 10:13 AM
DaCePtak0n's Avatar
DaCePtak0n
Concur with others where it's the cold...
Old Jan 4, 2012 | 12:38 PM
glassjaw047
Yeah thats what I thought too. That is what usually happens with cars when starting up when really cold out. The exhaust doesn't give out that big rev when first start up and the idle sound of the exhaust is a bit more quiet. If I can recall, the RPMS at idle were still the same I think...
G37xhibeet
Nov 15, 2016 09:29 AM
JoshB
Oct 15, 2015 03:08 PM
sedrick23
Aug 15, 2015 05:41 AM
Corvalis
Aug 6, 2015 04:36 PM
reigle9
Aug 6, 2015 02:45 PM
