Crackling noise under the car
Old Jan 30, 2012 | 01:42 AM
jesse550's Avatar
jesse550
So after driving it, there's a LOT of crackle under the car (sounds like pop rocks). It seems like it's normal but I never heard it in my old honda accord or my moms 3 series. Also I cannot distinguish where it's coming from, it sounds like its hopping from front to back under the car.
Old Jan 30, 2012 | 08:41 AM
OB G's Avatar
OB G
When do the noises occur? Any aftermarket parts installed? Any further info you can provide will help us diagnose your problem. Only think I can think of is maybe your sway bars need some lube or. Maybe part of your splash guard is loose.
Old Jan 30, 2012 | 09:26 AM
ModestOne's Avatar
ModestOne
I get the same thing... Think it's coming from the heat shields on the catalytic converters.
Old Jan 30, 2012 | 10:28 AM
Mayu's Avatar
Mayu
I am pretty sure it is just metal parts contracting as they cool down. True that it never happened to this degree in most of my other cars but I have never had anything with this kind of power output before. I would not worry about it...
Old Jan 30, 2012 | 03:41 PM
jesse550's Avatar
jesse550
Thanks guys, I have a stock car and it happens after I shut off the car, I'll try to get a video later on.
Old Jan 30, 2012 | 04:04 PM
KennyG37S's Avatar
KennyG37S
Mine is same thing, it has some cracking popping sound after you shut off the car.
Old Jan 30, 2012 | 04:10 PM
jesse550's Avatar
jesse550
Yeah it's probably normal. I heard a bit of it when I shut off the 3 series, just not to the same degree but then again the G's got more power so maybe that comes into play.
Old Jan 30, 2012 | 04:27 PM
seymore4's Avatar
seymore4
I'd bet its the catalytic converters cooling down, they tend to make noises sometimes
Old Jun 8, 2012 | 04:59 PM
Fire0nIc3's Avatar
Fire0nIc3
My 09 FX does it too:
https://www.myg37.com/forums/g37-cou...ml#post3465282
This is not normal during idle. Yes it is normal after the car is shut off but not while running!
Old Jun 8, 2012 | 05:54 PM
Topher9425's Avatar
Topher9425
It is the cats cooling off,and the metal contracting......
Old Jun 8, 2012 | 06:00 PM
Fire0nIc3's Avatar
Fire0nIc3
It's only suppose to do that when the car is shut off not during idle. If it's doing it while the car is running something is wrong.
Old Jun 8, 2012 | 08:08 PM
TwoThree's Avatar
TwoThree
You didn't plastidip the underside did you?
Old Jun 8, 2012 | 08:34 PM
jesse550's Avatar
jesse550
Nope. Just the emblems and wheels and that fugly chrome spoiler. Not sure why everyone has the impression that my whole car is dipped.
Old Jun 8, 2012 | 10:07 PM
TwoThree's Avatar
TwoThree
It was a joke man lol. Its the expansion and contraction of metals under the car as others have said, the exhaust and cats to be specific.
Old Jun 8, 2012 | 11:26 PM
Topher9425's Avatar
Topher9425
Did you miss the point where OP stated it was after shutting down the car????
