Tranny & Diff fluid change
Old Jul 6, 2011 | 11:20 PM
hechen507's Avatar
hechen507
I'm at 31k miles and I think its time to change the tranny and diff fluids. I would like to bring it to the dealer but the closest one is 3 hr drive. So one of my option is to bring it to shop in town (certified GM service center). My plan is to buy all the fluids and have them change it. Would anyone trust a Mr. Goodwretch to perform this service on there car?
Edit: I have a 09 7at X
Old Jul 7, 2011 | 12:31 AM
FM37's Avatar
FM37
I wouldn't trust ANYONE to touch my G! DIY!!! It's cake...
https://www.myg37.com/forums/d-i-y-i...ssion-oil.html
https://www.myg37.com/forums/d-i-y-i...-gear-oil.html
Old Jul 7, 2011 | 01:05 AM
hechen507's Avatar
hechen507
I have a 7AT awd, so isn't it hard to DIY the tranny?
Old Jul 7, 2011 | 02:01 AM
Wongster's Avatar
Wongster
The 7ATs do not require a transmission fluid change at 30,000 miles.
Per the 2009 service and maintenance guide:
Transmission Fluid – Automatic or
Manual, Differential Oil, Transfer Case Oil
Visually inspect for signs of leakage at
specified intervals. If towing a trailer,
using a camper or car–top carrier, or driving
on rough or muddy roads, replace the
transmission fluid/oil at every 30,000
miles or 24 months (except 7-speed automatic
transmission).
Also from the premium maintenance log:
Replace automatic transmission fluid
(except 7-speed automatic transmission)
Old Jul 7, 2011 | 02:32 AM
hechen507's Avatar
hechen507
transmission).
Good call! So when does the tranny fluid need to be changed? And will the same diff fluid changing tutorial will work on my X but I just need to do it to my front diff too right?
Old Jul 7, 2011 | 10:40 PM
white venom's Avatar
white venom
transmission).
I am wondering the same thing, I work for acura and we sell tranny service every 15k-30k miles. Why does it say not to service the 7at transmission??
Old Jul 7, 2011 | 11:06 PM
eksigned's Avatar
eksigned
pumping in tranny fluid is a PAIN IN THE ***. if i didn't already have the pump, i'd take to a mechanic. it's almost impossible to overfill either the diff of the transmission, but i'm sure it's possible in the wrong hands. if you'd like to give it a shot...go for it. it's relatively easy, but MESSY!
Old Jul 8, 2011 | 04:58 AM
hechen507's Avatar
hechen507
What about the transfer case? does that fluid need to be changed too?
Old Jul 8, 2011 | 09:50 PM
Mudgen's Avatar
Mudgen
The 7AT fluid change situation is weird. In the FSM it says in one place that it does not require changing as a maintenance item, but in the maintenance section there's a procedure for doing it. IIRC, it's drain, fill, drain, fill, drain, fill. Takes some special tools or a McGyverish streak.
Old Nov 13, 2011 | 01:17 PM
cobravin's Avatar
cobravin
where is the fill plug on the 7at trans, the service manual shows it on the bottom of the pan, how the hell does that work?, is it a one way valve ?, i would think it would be higher up on the trans like the rear diff fill hole, maybe the tube goes up inside the trans and can only come out when it gets to the top of the tube, anyone know, thanks
Old Nov 13, 2011 | 06:08 PM
Hapa DC5's Avatar
Hapa DC5
there are two plugs a fill and a drain. the drain is lower as the pan is molded upward.
checking the fluid is a pain in the *** in itself.
drewfinity
Nov 27, 2016 02:11 PM
cyberone28
Sep 25, 2015 02:31 PM
cyberone28
Sep 23, 2015 01:56 PM
ryang37x
Sep 22, 2015 05:33 AM
Upscale Speed
Sep 18, 2015 11:59 PM
