Slave Cylinder Failed :(
Old Jul 20, 2011 | 12:04 AM
Staples's Avatar
Staples
Well my hydraulic slave cylinder failed tonight. I was driving and coming up to a red light and I noticed the clutch was losing pressure. As I drove and shifted into 2nd, the clutch pedal went straight to the floor and I had to coast it 2 miles in 2nd gear, babying the car.
I'll be ordering the ZSpeedPerformance slave cylinder and will have that installed at my local headquarters (Hill's Garage in MD).
Has anyone had experience with flatbeds on lowered cars? I'll need to get my car towed and I'm dropped 1.75" on all 4 corners and I don't want to screw up my bumper or exhaust.
P.S. SouthBend Stage 2 clutch was on the car at the time.
Old Jul 20, 2011 | 02:47 AM
How long did your OEM slave last with the aftermarket clutch? I have Southbend Stage III and my OEM lasted about 9K. I put the heavy duty CSC in and it's been great so far.
I got flatbed towed and it screwed up my front bumper and Top Secret front lip. I got towed a second time and no damage at all. My car is definitely not slammed. The difference is in the operator. Tell them you are lowered when you call and ask them if they can guarantee they won't damage it. The operator should use board ramps to make sure you don't scrape going on or off. If you can take videos with your phone or have a camcorder be syre to video the car being put on and taken off. That way if there's damage they'll just pay instead if saying they didn't do it.
Old Jul 20, 2011 | 02:53 AM
NeverBoneStock's Avatar
NeverBoneStock
That sucks.. I installed the z speed hd slave when I put in my jwt clutch. My master cylinder started to go out right away.. Losing pressure big time. Thankfully it was replaced under warranty.. Good luck!!
Old Jul 20, 2011 | 04:47 AM
I did that too. I replaced the Master cylinder first, then the heavy duty CSC a week later. No warranty left on mine.
Old Jul 20, 2011 | 05:12 AM
G3708's Avatar
G3708
Same thing happened twice for the pass 6 months on my coupe. But did you know that if you fill the clutch fliud you can shift gear again but ofcurse if would ran out. Anyway my point is i did that till i got the car to my house. Then i got the car towed with flatbed since my car is lowered. They have to use 2 by 4 wood on both side wheels to get it up on the truck.
Old Jul 20, 2011 | 09:54 PM
Staples's Avatar
Staples
Thanks for the replies. I had about 4,500 miles on the clutch at the time the slave cylinder went out. The slave cylinder was brand new so it only had the same amount of mileage as the clutch. I had the bearing sleeve from ZSpeed since the HD slave cylinder wasn't available at the time.
I know I could have topped off my fluid, but when your slave cylinder fails there's only one place your fluid can go, and that's in the transmission housing. I'm sure my flywheel and clutch are both covered in fluid right now.
I'll make sure to take videos. I was VERY specific when I called that my vehicle is lowered and that it can not be damage otherwise will be holding AAA (them) liable.
Old Jul 20, 2011 | 10:06 PM
I had the exact same thing happen; replaced clutch, flywheel, OEM slave, Zspeed bearing (a few weeks before heavy duty CSC was released ). Mine died a very slow death over a lot of miles, not suddenly. 9K later replaced the master because I thought it had to be the problem. It worked only for a couple weeks and then went out again and I swapped out the heavy duty CSC. Works much better than ever now.
If I were you, I'd consider going ahead and replacing the master cylinder as well if possible. It's about $100 for the part. You will be very pissed if you upgrade the CSC only to have another component fail in a short time and have it die on you again.
FWIW, I didn't lose fluid when the CSC or master failed, but I could not bleed all of the air out if the system. It was causing cavitation that was inducing air into the line no matter how much I tried to bleed it.
fuzzed
Aug 21, 2020 09:35 AM
ZSpeedPerformance
Drivetrain
12
Sep 9, 2016 11:20 AM
stevo4756
Oct 9, 2015 01:54 AM
r0cketm0nkey
Sep 18, 2015 10:16 AM
