G37 engine rattling noise after galley gasket repair
Old Oct 6, 2019 | 08:52 AM
Eugenius's Avatar
Eugenius
Engine rattling noise after galley gasket repair
This has started right after the galley gasket repair at 90K miles. The noise happens only at around 2500 RPM.
The noise is coming form engine itself.
Both catalytic converters were replaced by new EOM ones. And it is not heat shields as I knocked with rubber mallet everywhere.
Please help identify the problem/
ps I'm sick and tired fixing this car.
https://youtu.be/HhKi4Pi2IS0
Old Oct 6, 2019 | 11:13 AM
slartibartfast's Avatar
slartibartfast
I can't say what the noise is, but a surprisingly common source of rattle is the windshield washer reservoir cap.
Old Oct 6, 2019 | 12:02 PM
Eugenius's Avatar
Eugenius
This noise is very pronounced even 100 feet away.
i don’t think plastic cap would make such rattle.
Old Oct 6, 2019 | 12:26 PM
PNW_IPL's Avatar
PNW_IPL
Take it back. Something was incorrectly repaired or left un placed. Definitely something rotational in the engine.
Old Oct 10, 2019 | 11:37 AM
Eugenius's Avatar
Eugenius
The shop is reporting that the engine probably severely damaged due to low oil pressure and need new engine.
Which is hard to swallow at this point as the Blackstone lab is returning all the time below average metal results and there was no noise like this before.
Old Oct 10, 2019 | 11:39 AM
PNW_IPL's Avatar
PNW_IPL
I'm calling BS. The gallery gaskets do not mean damage to the engine. It can be ran fine for years. Hell most dont even know they have the issue.
Old Oct 10, 2019 | 01:07 PM
Eugenius's Avatar
Eugenius
Yeah, sadly, I sense the same.
this is the exact response form the shop:
Eugene,
Removed timing cover and found oil galley gasket job completed correctly, no loose parts or missing. Found main tensioner and upper tension guide worn, also found retaining tabs on upper guide missing. Recommend to replace and recheck, if noise is not gone suspect worn timing components and would recommend a used engine over redoing entire timing components.
We see slight wear on tensioner and the the broken retaining tabs on the guide at the top, recommend replace and recheck
The total amount again $1100
Old Oct 10, 2019 | 01:10 PM
PNW_IPL's Avatar
PNW_IPL
They should have told you all this before resealing the engine. That really blows. Idk man. I dont think you have much recourse. Maybe a second opinion. Or drive it until it blows and swap it. Sorry man.
Old Oct 10, 2019 | 01:24 PM
Eugenius's Avatar
Eugenius
Thank you for the support, feeling down little bit
Old Oct 10, 2019 | 01:54 PM
Eugenius's Avatar
Eugenius
Btw It is a reputable nissan/infiniti shop around our area and doing a lot of galley gaskets repairs, but seems like my case is different.
Don't know what to think now...
Old Oct 10, 2019 | 04:20 PM
Conboss's Avatar
Conboss
Listening to that it almost sounds like the timing chain guides. My dad had an Audi that when not properly lubricated (Like on cold-start) would make a noise incredibly similar to that. Motor was pulled and tensioners and guides replaced. Noise disappeared.
It would either be that, or there's a chance the shop straight-up didn't tighten the tensioners or some other parts in the same area. It's not right, they should be replacing the parts on their dime IMO.
Old Oct 11, 2019 | 08:40 AM
Eugenius's Avatar
Eugenius
Thank you. The manager at the shop says that the technicians always check everything before putting the front cover back and there was no noise when I picked the car.
I do not think it is possible to win the argument here, as I was not there looking over shoulder when they were fixing for first time.
I'm really hoping that this will fix the issue, if it checks out then it would be recommendation for others to replace the tensioner and guides during the gasket job.
Old Oct 11, 2019 | 12:27 PM
tiguy99's Avatar
tiguy99
Time for an attorney.
May be cheaper to have legal counsel intervention vs going back and forth with the shop.
Few phone calls may be worth it in this case
Old Oct 15, 2019 | 01:49 PM
Eugenius's Avatar
Eugenius
Thumbs up
Listening to that it almost sounds like the timing chain guides. My dad had an Audi that when not properly lubricated (Like on cold-start) would make a noise incredibly similar to that. Motor was pulled and tensioners and guides replaced. Noise disappeared..
You were right on the money. After the shop replaced tensioner and guides, noise is gone, at least for now.
Old Oct 15, 2019 | 02:56 PM
Eugenius's Avatar
Eugenius
This shop is a family business and looks like good people are running it.
I tend to believe what they are saying and doing.
Besides there is no such shop around which is specializing on Nissan/Infiniti products and has a lot of expertise in it, except dealerships which charge way and way more.
bostonlines
Mar 24, 2015 10:43 AM
derekc89
Nov 2, 2012 05:40 PM
mad_g37
20
Feb 13, 2012 02:11 AM
cruzmisl
Aug 20, 2011 04:56 AM
SilverBullet
Nov 7, 2008 12:39 PM
