Help Whining on Cold Start up Only
Old Oct 7, 2019 | 09:44 AM
Notfelix's Avatar
Notfelix
Hello,
My 6MT sedan started making a whining noise at start up ever since it started getting cold at night. I live in GA and it began getting cold this past weekend and temperatures were at like 50-60 degrees at night. When I start the car, there’s a whine that last maybe less than a second then vanishes . At first I thought it was the belt but a belt makes a screeching noise , not a whining like this .
The whine sounds exactly like a supercharger whine up , as a way to describe it
it only does this when the car is left over night and started as the temperatures started to drop. But warm start ups and if I leave the car alone for several hours, the sound isn’t present . Only happens in the morning when I go to work. Other than the noise , the car doesn’t have any other issue. I checked the fluids and they all look good.
Has anyone had a similar sound or thing happen to them? If so , did you get it fixed and figure out what it was?
Old Oct 7, 2019 | 09:58 AM
Conboss's Avatar
Conboss
PS pump? I know at least mines on it’s way out, and in the bitter cold last winter it was making all sorts of weird noises on cold start.
Old Oct 7, 2019 | 10:42 AM
JSolo's Avatar
JSolo
Just say no!!!!!
Mine sounded this way after getting fully warmed up, while warm/hot outside (50F+). Turned out to be the p/s reservoir. There is/was a tsb which replaces it with an updated version. OP's issue may be different because it happens briefly, and when cold.
Old Oct 7, 2019 | 12:31 PM
Notfelix's Avatar
Notfelix
So was it only the reservoir ? And how much was the part? Mines is only on cold start
Old Oct 7, 2019 | 01:38 PM
JSolo's Avatar
JSolo
Just say no!!!!!
Correct. Cost to me was $0 as the car was still within factory warranty period (4yr/50K). I do believe retail on the res was something like $200+ . Crazy!
Noise on cold start may very well be something else. Level good?
Old Oct 7, 2019 | 03:46 PM
Conboss's Avatar
Conboss
I'm currently dealing with a whine as well, I've noticed sometimes driving next to a wall, either side, there is a small p/s pump whine. I know its going bad though. I have another whine that reveals itself after a hard pull to redline. I drive an empty on-ramp, run it right out till a sharp bend, floor it for 2 more seconds and I'm at a stop soon after. I haven't for the life of me been able to figure it out, but it isn't the p/s pump. Doesn't sound anything like it. However it does match up with engine revs.
Old Oct 7, 2019 | 09:26 PM
Notfelix's Avatar
Notfelix
Yeah, my accord I had before would leak constant PS fluid so it would end up whining after a while and I know how a PS whine sounds like so I don’t think this is it. It sounds like when you try to run the starter when the car is already running . If that helps
Old Oct 8, 2019 | 10:26 AM
Conboss's Avatar
Conboss
I’m not sure I’d say it sounds like the starter winding up, it almost sounds like a really small vacuum leak... problem is, car runs like a top, no CEL’s, and I don’t hear it once I pop the hood. It’s very frustrating, but I’m surviving so far. Going to stick a camera or a microphone under the car to see if I can pick it up
Libster
General Tech Questions
Nov 6, 2019 05:54 PM
Jan 21, 2013 06:40 AM
Infiniti7
Dec 23, 2010 11:43 AM
Trader_J
32
Mar 6, 2008 03:38 PM
brd_ptty
18
Mar 2, 2008 03:51 PM
