P0340 code
Old Dec 2, 2019 | 10:31 PM
G37sreyes's Avatar
G37sreyes
P0340 code
I have a 08 g37s manual coupe. I have had this code(p0340) for a while. I put in work to change my engine and found a donor and just recently swapped the engine with less miles. Replaced the passenger side front camshaft sensor on the new engine. The same code(p0340) has came up. Car is in limp mode even with the new engine
Old Dec 3, 2019 | 05:16 AM
Said Amir's Avatar
Said Amir
I haven't had this issue with my G37, but had it on my friends camry, and it was due to the wiring that was messing it up. We replaced the camshaft sensor 3 times, but we just had to disconnect the wirings and use some electric cleaner spray on all the connections and it worked. Since you replaced the engine did you use the wires that came with it, or did you use your own from the old engine? If anything trace back make sure none of the wires and being stretched, and clean the connectors and try giving that a shot.
Old Dec 3, 2019 | 06:14 AM
Surfnazi's Avatar
Surfnazi
Is the harness damaged?
Old Dec 3, 2019 | 05:14 PM
G37sreyes's Avatar
G37sreyes
Thanks guys and the new engine came out of a 2012 g37x auto and I reused my wiring harness and ecm. I checked and there is no voltage coming from the three pin connector
Old Dec 3, 2019 | 05:15 PM
G37sreyes's Avatar
G37sreyes
The wires themself look in good condition does anyone know the pin assignment on the ecm side
Jah.37x
Jul 31, 2021 10:42 AM
0MGG37
Jun 18, 2019 01:05 PM
LXNg37
May 23, 2019 08:46 PM
Romeo0119
Oct 19, 2012 10:31 PM
