Losing coolant, smoke and noise
Old Nov 7, 2019 | 11:38 AM
Conboss's Avatar
Conboss
Popped the hood last night cause I heard what sounded like a drip on my exhaust. Checked coolant, it’s at halfway between full and min on the reservoir. I’ve also noticed some white smoke from the tail pipes. I have not done any tests just yet, will be getting a pressure tester to check out the system. Hoping it’s the T going to the heater block (if memory serves that’s where it is)
anything else I should check out while I’m at it? Really hoping for a bad plastic coupler.
Old Nov 7, 2019 | 11:42 AM
Surfnazi's Avatar
Surfnazi
Head gasket leak possibly, check oil and ser of you see coolant in it
Old Nov 7, 2019 | 12:21 PM
Infin88's Avatar
Infin88
How much white smoke is too much that it would cause concern. If coolant was mixing with oil wouldn’t there be a sweet smell?
Old Nov 7, 2019 | 01:44 PM
JSolo's Avatar
JSolo
Just say no!!!!!
You sure it's not just steam? Is it cold where you're at? Does the smoke have a sweet smell/taste to it?
Old Nov 7, 2019 | 01:59 PM
Conboss's Avatar
Conboss
Speaking about this morning, the car was 90% warmed up when I let it sit running for a couple mins while I went into the tims for a coffee. The smoke was enough for me to think it was something, but I’m still not sure at this point. I’ll check the oil and coolant levels again later once I drive home, I’ll also grab a video of the smoke I’m seeing.
as said above I’m going to grab a pressure tester for the cooling system, probably going to be a weekend project. Really hoping it’s not a head gasket...
Sidenote, it’s been a couple tanks now but I did run seafoam through the fuel system to try and resolve a ticking injector. No dice, will probably have to replace that injector soon. Could the seafoam still be in the tank? I ran it pretty dry after I put it in
Old Nov 8, 2019 | 02:59 PM
Conboss's Avatar
Conboss
I wasn’t able to get a good video last night, however I checked my oil. It appears to be perfectly fine, no milkiness, and filler cap is also clean. At this point I’m not too concerned about a head gasket, however I’m still going to get a pressure tester kit and see what I’m looking at.
Old Nov 8, 2019 | 10:07 PM
JSolo's Avatar
JSolo
Just say no!!!!!
You never answered the questions in post #4.... Unsubscribing.
Old Nov 9, 2019 | 11:13 AM
Conboss's Avatar
Conboss
Apologies, completely missed it. Yes it is getting cold, however when it was not so chilly it was producing the same amount of smoke/steam. Planning on doing the pressure test later today, so I hope to have some news
Old Nov 9, 2019 | 12:20 PM
Conboss's Avatar
Conboss
https://imgur.com/a/2efeck8
Video of the steam, tips dripping water. I’m gonna say it’s condensation, just took time for me to realize. Just got the tester, have to drive around a little bit today. Hoping to get this done later tonight.
Old Nov 10, 2019 | 11:00 AM
Conboss's Avatar
Conboss
Currently testing pressure. Won’t hold 14psi for more than a minute. Can’t seem to find the leak, haven’t seen any drips. I know that it’s going somewhere, as the coolant level has dropped
Old Nov 10, 2019 | 05:57 PM
Selym's Avatar
Selym
If you're absolutely sure it isn't leaking externally, pull all six plugs, pressurize the cooling system with your tester, and have a look in each cylinder with a borescope. If you find coolant in any of the cylinders, look around with the borescope to see if there's a head gasket failure, crack in the head, or crack in the cylinder wall.
Mysteak
Sep 9, 2019 12:33 PM
venkatasai1989
17
Feb 12, 2019 03:49 PM
tite_tite
Feb 7, 2019 02:36 PM
Bossman
Nov 6, 2017 03:25 PM
tite_tite
Sep 25, 2015 10:21 PM
