Help DTC U0101 G25 Wont start need help
Old Nov 20, 2019 | 06:51 AM
tigran199102's Avatar
tigran199102
Hi everyone who can help error code is u0101 CAN comm error or TCM, car is Infiniti g25 2011 wont start, I check all fuses replace shift selector, car now don't have headlamps, acc is on but it wont start and don't show gears on dash like in video, show yellow key. Ans sorry for my english
Old Nov 20, 2019 | 09:56 AM
Conboss's Avatar
Conboss
Usually a solid yellow key light indicates a problem on the vehicle side, and it’s not cycling to off when you have the brake applied. The fob should be good. Check the steering column lock, that prevents the car from starting. You may also have an issue with the bcm. There’s plenty of other forums out there
Old Nov 20, 2019 | 10:01 AM
tigran199102
Car detect key, brake stop signal button is ok, and check starter and starter relay its ok too, I don't know how to check BCM
Old Nov 20, 2019 | 02:19 PM
Conboss's Avatar
Conboss
From what I gather, the key is detected. If you can move the gear selector, then the brake switch should be fine. I’ve only had a UXXXX code come up when my car didn’t shut down one time, failed to communicate with HVAC or something. At this point I’d suspect BCU, but check fuses/relays and the like.
Old Nov 21, 2019 | 04:13 AM
tigran199102
Yes you are right key detected, gear selector is moved, i try to check BCM module in few days
Old Nov 27, 2019 | 04:47 AM
tigran199102
thank you for answer Conboss, I fix it in my car its corrosion in driver side can connector and check a/t fuse in fuse box behind battery
Old Nov 27, 2019 | 02:49 PM
Conboss's Avatar
Conboss
Glad to hear you found a fix! Maybe post a picture of the connector at fault for future members?
Old Nov 28, 2019 | 08:00 AM
tigran199102
I dont have pictures but everyone feel free to questions
Old Nov 6, 2023 | 04:56 PM
Chrishino031's Avatar
Chrishino031
hey! Im having similar issues, do you know where the cable connection is?
frank37
Feb 21, 2024 09:05 PM
Twista
May 9, 2022 02:14 PM
AdamBritt
General Tech Questions
Mar 19, 2019 08:59 PM
Billyboy57
Dec 1, 2016 04:31 AM
