shifting into 6th gear?
Old Oct 30, 2011 | 07:45 PM
Manny22's Avatar
Manny22
don't laugh guys but im scared to shift into 6th gear, i feel like i might accidently shift into reverse and **** my transmission up.
Honestly all i see is 6 gears (including reverse) so im confused. LOL
Old Oct 30, 2011 | 07:51 PM
TVPostSound's Avatar
TVPostSound
IF ITS A 6MT:
Straight down from 5th, reverse needs a push to the right, and down.
Might you have a 5MT??
Itchytoe's Avatar
Itchytoe
If you're at a speed where you need to shift up to sixth gear, you won't be able to get it into reverse. Even if you push the shift lever down and allow yourself to move it into that fork, you won't be able to get the teeth to mesh. You don't have syncros in reverse, so you won't wear that out.
Just pull the shift lever straight down from fifth and you'll be fine. You can even push it against the right side to make sure you don't hit fourth by accident. It's a little weird when you get your first 6 speed instead of the old 5 speeds, but you get used to it quick.
Old Oct 30, 2011 | 08:24 PM
davv1215's Avatar
davv1215
It is weird (never had a 6 speed) but if you shift straight down from 5th all the way to the right w/o pushing down you should be fine.
davv1215's Avatar
davv1215
I should say never had a 6MT until now.
Old Oct 30, 2011 | 09:47 PM
Your car has a reverse lockout. Not gonna happen.
Old Oct 30, 2011 | 10:07 PM
fairladyz34's Avatar
fairladyz34
^ /thread
37
Oct 17, 2020 11:12 AM
r0cketm0nkey
General Tech Questions
17
Nov 23, 2015 03:34 AM
Jonesmeister11
Sep 27, 2015 08:28 PM
Sep 25, 2015 01:38 PM
