Problem with DS mode when stopping
Old Dec 12, 2011 | 06:51 PM
sebounet's Avatar
sebounet
It happens to me a few time, and i like to know if it happens to some of you.
When i m in DS , i brake to slow down to a full stop. When the car is almost stopped , it does a rev matching, and the car jump for 2 or 3 feet. It could scare some people crossing the road and me if i m to close to someone or another car.
Old Dec 12, 2011 | 07:10 PM
bocaytomas's Avatar
bocaytomas
Same thing happens to me in manual mode, going from 2 to 1 is pretty rought
Old Dec 12, 2011 | 10:10 PM
devil2k's Avatar
devil2k
Same here. It's annoying.
Old Dec 12, 2011 | 10:40 PM
jasyn's Avatar
jasyn
if it's the 7AT, do the reflash https://www.myg37.com/forums/g37-sed...reprogram.html
Old Dec 12, 2011 | 11:17 PM
Tazicon's Avatar
Tazicon
Neither of my 7ATs do that so it could be in need of a reflash
Old Dec 12, 2011 | 11:38 PM
TinsleyC's Avatar
TinsleyC
Mine has jumped forward a bit on most low gear downshifts. The rev matching tends to over rev, causing a power forward when the new gear hits. I'd love to tune mine down some.
I've had all the ITB's applied. No effect on that.
Old Dec 13, 2011 | 12:45 AM
firstinfiniti's Avatar
firstinfiniti
Next time you do it, check to see if it actually pushes the car forward or is it the sudden lack of engine breaking mid-shift that gives the impression of it lunging forward. I used to feel the same way until I experimented while coasting to a stop.
Old Dec 13, 2011 | 04:53 AM
INFINITI G37's Avatar
INFINITI G37
Its fine with me..
Old Dec 13, 2011 | 11:49 AM
bitNine's Avatar
bitNine
ALLLL THE TIME... I have the latest flash.
I think it's the release of the torque converter happening too late, causing a lunge.
Old Dec 13, 2011 | 01:06 PM
rabbit's Avatar
rabbit
I usually only use DS when on the highway or somewhere/when I won't be coming to a complete stop anytime soon. Isn't that what it's for? Maybe that will fix your problem
Old Dec 13, 2011 | 01:29 PM
devil2k's Avatar
devil2k
DS is for when you want to keep the rev in the power band but you don't want to change gears yourself. It's extremely fun in corners. I usually just put it into manual to avoid this problem but sometimes it still happens when it automatically downshifts from 2 to 1 at lower speed.
Old Dec 13, 2011 | 01:41 PM
rabbit's Avatar
rabbit
Actually now that you mention it.... the same thing happens to me in M mode.
Old Dec 13, 2011 | 01:45 PM
Soliditude's Avatar
Soliditude
DS isn't really meant for stopping, in the first place. It's intention is for when you wanna gun it and drive fast, thus, the gear changes are more harsh. You'll always get it when stopping.
Old Dec 13, 2011 | 05:44 PM
sebounet's Avatar
sebounet
Thank you all. In fact i love using it in cities, it's faster when you need to take off or re accelerate. The gears changing less often, i don't need to brake hard or often.
It's the same thing but worse, when you are at a stop, and you have the foot on the brake but just enough pressure to not going forward. And suddenly the AC kicks in and you need to brake harder to avoid to going forward.
It could be the torque converter as someone said, or the rev matching arrives too late.
ill12will8
Oct 26, 2015 10:09 PM
pcwd
Sep 15, 2015 10:06 PM
drewfinity
Future Models
Sep 15, 2015 12:49 PM
SuicidalG37SGuy
Sep 10, 2015 06:01 AM
