Details on 0-60 mph throttle restriction?
Old Oct 27, 2011 | 06:01 PM
blackhawksfan81's Avatar
blackhawksfan81
I've seen several references to this (usually concerning the Hypertech) but can't find any substantial info. Can anyone share some details?
Old Oct 28, 2011 | 09:00 PM
TheLocNar's Avatar
TheLocNar
In stock configuration, you cannot redline below 60mph.
Old Oct 29, 2011 | 11:38 AM
TVPostSound's Avatar
TVPostSound
Not true.
Old Oct 29, 2011 | 05:44 PM
G37Sam's Avatar
G37Sam
Source please?
Old Oct 29, 2011 | 06:09 PM
TheLocNar's Avatar
TheLocNar
Hmmm. On the 7AT it never would that I noticed. I thought it was to help with fuel economy.
Old Oct 29, 2011 | 06:22 PM
TVPostSound
I would always bounce off the limiter as it shifted in 2nd. I doubt I was doing over 60mph in first!!
Old Oct 30, 2011 | 10:16 AM
Adam West's Avatar
Adam West
The car will definitely hit redline or just before the limiter in a full-throttle run starting from a dead stop in DS-mode. I've also manually shifted and it will slam into the limiter if you're late with the shifting. From what I've read about the 0-60 throttle restriction, basically they are limiting the amount of throttle plate opening to less than 100% during a full-throttle run from 0-60, could be to preserve the drivetrain or even emissions. I don't know if this has been confirmed on our cars or other Nissans, but I remember hearing a lot of speculation that it did exist from multiple ECU tuning vendors.
Old Oct 30, 2011 | 11:49 AM
blackhawksfan81
Thanks for the info. Strange how there's so little concrete info and most of what I've found seems to be marketing blurbs for tuner/chip companies.
Old Oct 30, 2011 | 11:58 AM
TheLocNar's Avatar
TheLocNar
Yeah my bad. That's in DS or M mode, correct? I don't recall being able to redline in just D, but then again, I've had the HT even before I got the car... lol
Old Oct 30, 2011 | 12:33 PM
TVPostSound
D is more conservative than DS in regards to shifting, and rev hold.But it can.
The so called "0-60" throttle restriction is that the throttle plates dont open as fast as you push the pedal.
Just last week, I reverted my UpRev tine back to stock, for a dealer Nav update, and relived the horror!!
I was making a left at the light, slammed the throttle, and the car fell on its face for a second, almost allowing the oncoming car to hit me.
I then remembered why I originally bought the HT!!! I since got an UpRev.
Old Oct 30, 2011 | 11:42 PM
eksigned's Avatar
eksigned
...i'm slightly confused. doesn't the limiter hit prior to redline? therefore, not allowing redline? i went from 3rd to 2nd a while back on the freeway a week ago...not realizing i was already so high the revs. 2nd hit off the limiter before redline. end of story. i'm tuned though -- so my rev limiters set a small bit higher.
OP: aren't you talking about the throttle flaps though? or am i just not...understanding your question? without a tune -- the throttle flaps don't open to 100% during WOT runs. I believe...60-70% was the total position of the throttle body flaps.
Old Oct 31, 2011 | 09:49 AM
TVPostSound
Limiter is set to hit AT redline 7500 RPMS
Old Oct 31, 2011 | 11:18 PM
Ibanez540r's Avatar
Ibanez540r
Is this true? Max 70% throttle under 60MPH?
linvbro
Aug 22, 2016 01:25 PM
rob145
Mar 28, 2016 01:28 PM
MrRiv
Sep 29, 2015 04:59 PM
dedmanchan
Sep 24, 2015 11:25 PM
