PDA
View Full Version : Brakes, Suspension, Wheels & Tires
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37
  1. Recommendations on rotors and brake pads
  2. Help wheel shaking at speeds above 60mph
  3. Help Rear coilovers
  4. 370z steering?
  5. Help wheel bearing or brake noise?
  6. Active Tire Info (PSI / Temp)
  7. Staggered to Square
  8. G37x Coupe Front Lower Control Arm
  9. Does the tpms 'trick' synch new tpms or just eliminate the light?
  10. Power Steering all of a sudden went out?
  11. Cheap OEM RIMS?
  12. Help: wheel spacers
  13. Aftermarket toe bolts vs. adjustable toe arms
  14. Help Air suspension help
  15. HELP-- EXTREME tire wear on coilovers
  16. Help Bc coilover rear lower mount search
  17. Rack and pinion
  18. Getyourwheels: "incorrect width" on 19×9.5 square setup
  19. Strut Mount
  20. Power steering boiling. (Video attached)
  21. Offset Help
  22. Help Lug nut questions
  23. Eibach Springs and Spacers on 18'' Work Wheels
  24. Power Steering Rack - Any adjustment for wear?
  25. Recommendations
  26. HELP ~ Will a QX60 rim fit on a G37X?
  27. Help G37x - rattling brake calipers. How can I fix this?
  28. Rotor upgrade - change offset via rotor possible?
  29. Tire rotation
  30. TPMS missing?
  31. I'm planning on buying 20s for my 2011 G37xS coupe. Need some advice.
  32. bc coilovers: rear left stick out
  33. Help Brake Caliper Bolt Sizes
  34. Offsets
  35. 2010 G37x Rear Brake Rotor Pad Sizes?
  36. Help Front sway bar bracket
  37. Grease gun and zerk size?
  38. Help Sway bar replace question
  39. Help What parts are these???
  40. Nobody can figure out why my front left wheel is always cupping
  41. Life expectancy of SPC parts?
  42. Adjustment of parking brakes/drums from hub, SPORT/Akebono
  43. can anyone tell me if front 9.5 +22 and rear 10.5 +22 will fit a G37s coupe 08
  44. Help Wheels Website
  45. Sport coupe wheels and tire setup question..help!
  46. Rock Auto: Z23 Evolution Sport w/Calipers $815
  47. G37 Fitment 245 275 on BC Coilovers
  48. Should I get new tires?
  49. Eibach pro with spacers
  50. Broken front swaybar end link. Okay to drive?
  51. Help identifying a set of wheels + suspension
  52. Changed all brakes to Stillen rotors and hawk 5.0
  53. Four Wheel Steering?
  54. Creaking noise in steering when cold and not moving
  55. Do these look like 19s or 20s? (forgestar f14)
  56. Help wheel set up
  57. Tein Monoflex Coilovers with no spring
  58. G37s coupe close ratio steering difference?
  59. My G37S is making weird noise when I turn left and right
  60. Master Cylinder
  61. Stock arm adjustability? Alignment after coilovers.
  62. Staggered to Squared
  63. cant pass 2k rpm!
  64. 2017+ Red Sport Wheel fitment
  65. anyone know what this leak is?
  66. Help Bc racing or Tein Flex z Coilovers???
  67. Advice Seriously Needed
  68. Help Traction control light on
  69. Hit a 5 inch center divider on the freeway at 75mph...
  70. linear adapter needed for swift springs on 09 g37x coupe with bc br coils
  71. Brake difference between 2008 and 2013 G37S
  72. ordering tires
  73. 2013 G37 wheeks
  74. Changed rear tires same measurements 275/30 r20
  75. Wheel size help!!
  76. Replacing my wheel bearing
  77. Is this a mild drop? What kind of springs can give me this?
  78. Fist Post, hi, Akibono questions
  79. Vossen VFS2 fitment
  80. Suspension Suggestions
  81. Help SPC Rear Camber Adjustment
  82. swift springs
  83. G37 Rotor Size?
  84. What's the size of these bolts?
  85. 255's ona 8.5 inch rim ok?
  86. Black Friday/Cyber Monday 2017 - Deals Start Now!
  87. What car do i have?
  88. 2009 G37xs sedan.. What’s my rotor size?
  89. Help Staggered 19s wheels
  90. Suspension is shot...brakes...shot
  91. Settling springs on a slope
  92. Coilover Suggestions 13 Sedan RWD
  93. Do different wheel specs require an alignment?
  94. Uniroyal Tiger Paw GTZ Tires
  95. Spacer help
  96. Newbie here:need help understanding my suspension
  97. Advice: Wheels for 09 G37s vert
  98. 2013 Sport Sedan Steering Whine
  99. Strange noises
  100. Is there any way to add more resistance to steering?
