Rock Auto: Z23 Evolution Sport w/Calipers $815
Old Apr 3, 2018 | 08:43 AM
ANMVQ's Avatar
ANMVQ
Question Rock Auto: Z23 Evolution Sport w/Calipers $815
Hey guys,
Anyone tried these or thoughts thinking of getting this set up for my Q50. Would be the same set up just with centric blank rotors 12042100 and 12042105. Thank you
https://www.rockauto.com/en/moreinfo...300363&jsn=384
High-performance rotor, pad & caliper set delivers the big brake feel without the big brake price
Custom-matched components are engineered to work together for maximum performance
Pads, rotors, & calipers crafted for your specific year, make & model vehicle
Kit includes high-performance carbon fiber/ceramic brake pads, a complete set of cross-drilled and slotted rotors, and red powder coated calipers
Power Stop Z23 Evolution Sport Brake Pads:
Carbon Fiber and Ceramic Compound
High temperature threshold to resist fade during extreme driving
Quiet, low-dust ceramic formula
Shims made with dual rubber layers over constrained steel to eliminate noise
Premium stainless steel hardware kit included where applicable
High temperature ceramic lubricant included with every pad set
Power Stop Drilled & Slotted Rotors:
Drill holes reduce brake temperature
Slots sweep gas and dust away for solid pad contact
Silver zinc plated to resist corrosion
Precision machined for exact OEM fit
Power Stop Caliper Features:
Electrostatic powder coating resists corrosion
100% pressure tested to prevent leaks
Brand new components including bleeder screw, hardware and pins
High temperature EPDM rubber for extended life
Premium silicone lubrication for smooth operation
Remanufactured in Power Stop's Chicago, IL facility
Old Apr 3, 2018 | 08:53 AM
RMB5190's Avatar
RMB5190
I've definitely thought about it and I know I read a post where someone gave them a shot and I believe Brad had some insight on the product. From what I remember, the person who bought them was satisfied. I'll see if I can dig it up but I believe it's in the 'What did you do to your sedan today' thread.
Old Apr 3, 2018 | 09:02 AM
ANMVQ's Avatar
ANMVQ
Cool thanx man! I hope Brad chimes in also
Old Apr 3, 2018 | 09:07 AM
RMB5190's Avatar
RMB5190
Pg 290 of that thread #4346 I believe is the ones you linked to.
He just got the calipers though.
Old Apr 3, 2018 | 09:51 AM
ANMVQ's Avatar
ANMVQ
Thanx man~
Old Apr 3, 2018 | 10:01 AM
Here you go~Not sure of the exact specific differences between the Z23 and Z26 sets though
https://www.myg37.com/forums/brakes-...-calipers.html
Old Apr 3, 2018 | 11:41 AM
ANMVQ's Avatar
ANMVQ
Thanx Brad
Old Apr 3, 2018 | 01:19 PM
ANMVQ's Avatar
ANMVQ
Just bought the kit, was actually less cause I want with the centric blanks . Should be here the end of next week and will try to get them installed and reviewed by Saturday. Still can't believe the poor quality of the stock breaks :? , 38K and vibrations and squealing .
Crazy this was HALF the price as the Z1 kit
Old Apr 3, 2018 | 02:44 PM
RMB5190's Avatar
RMB5190
Subbed for the review. I have these saved to my build list for down the road so I appreciate you taking the plunge.
Old Apr 3, 2018 | 02:54 PM
slartibartfast's Avatar
slartibartfast
I'm not a fan of drilled or slotted, but otherwise looks adequate.
Old Apr 3, 2018 | 03:14 PM
ANMVQ's Avatar
ANMVQ
Thanx guys, will have a review ^^ I'm not a fan either of drilled/slotted I still have BRAND new 10 days old Z rotors that wrapped right away and can cut them . I went with the Centric blanks
Old Apr 12, 2018 | 07:04 PM
ANMVQ's Avatar
ANMVQ
So everything is here I also grabbed som bangs bolts from Z.
Stuff looks pretty good and goes on tomorrow
Old Apr 12, 2018 | 07:16 PM
Nice! Look forward to your install & impressions!
Old Apr 19, 2018 | 12:46 PM
Overboard's Avatar
Overboard
I bought them a couple of months ago, and they're pretty great. Only two minor "complaints":
First, I do have a bit of a squeaky pad, driver's side front. I suspect it just needs to be lubed properly, as it was super cold when I installed them out of necessity, and I may have skimped on the lube.
Second (maybe related) the supplied pads will squeak a bit when cold.
Otherwise, they're really great. Very very low dust, and a good improvement over stock. Definitely worth the money.
Old Apr 26, 2018 | 12:38 PM
Snaoum's Avatar
Snaoum
Let me know how the install goes. Are you putting them on yourself?
