Changed rear tires same measurements 275/30 r20
Could I get some help please
Have tein basis coilovers with front/rear spc control arms & camber kits
Was running nexen 275/30 20 in rear & never rubbed - I have family of 5 in the car & never rubbed in the back
Got some Achilles tires 275/30 20 & they did alignment & car now rubs with whole family in the car
The tires were such a deal 90$ for each tire - couldn’t turn it down
Different brand of tire & alignment is making it rub?
What would easier & cheapest
raising car ?
Adjusting alignment
Rolling fenders
Thanks for the help
raising car ?
Adjusting alignment
Rolling fenders
Thanks for the help
Kpmikey808 (01-04-2018)
Would more negative camber make tires wear out uneven
Kpmikey808 (01-05-2018)
Couldn’t print it out
It couldn’t print out that day & I cannot remember what he said
Alignment was 40$ & unlimited alignment for next 3 months
I plan on going & taking a pic of numbers on 🖥
I really don’t understand all those numbers with toe/camber & stuff - just a lil confusing to me lol
Maybe I can find the perfect specs for the best tire wear
Thinking of going springs & shocks way -
b thx for all yr expertise & knowledge on our car
Unless aftermarket adjustable upper control arms are installed, there's no changing front camber. Only toe is adjustable from the factory. Rear can adjust for camber. Most people shoot for 1.5 degrees negative camber, I run 2 degrees negative front and rear for extra bite in turns.
Aim for factory toe settings.
Kpmikey808 (01-07-2018)
thats what i was thinking
i want my tires to last longer
what would be a good number for negative camber
is there a perfect spec set up for alignment
is there or could somebody send me a pic of good numbers for alignment
toe castor
rear camber
don't know to much about these numbers
toe castor
rear camber
Mikey, here's a sample spec sheet, I'd try to keep everything except camber within the specified ranges (caster can be a bit off too without ill effect, in fact I like extra caster ) For sedans the spec range for camber is a bit lower, but when keeping toe in spec you can push that up. I wouldn't go more than -2 unless you must to get the tires to clear.
The following 2 users liked this post by slartibartfast:
blnewt (01-07-2018),
I’m gonna take that with me
U think tire rub in rear will be better after lifting to 26.5
Is it hard to use wrench on tein basis coilover to lift a little
I have mine at 26.25 all around (was at 25.75 on B&G springs) and the ease of getting around the streets is SO much better, so for that reason alone I would recommend a bit higher, even a 1/4".
BurtoN86
13
07-23-2015 11:53 PM
NWG37S
03-01-2011 08:12 PM
