Help G37x - rattling brake calipers. How can I fix this?
Old May 30, 2018 | 11:49 PM
llebcire's Avatar
llebcire
I've been chasing front end noises since purchasing my 2011 G37x last fall especially a metallic rattling when going over bumps that disappears when I lightly engage the brakes. While rotating my tires this weekend I found both front calipers rattle excessively and sound like the noise I hear – check out the video below.
Questions:
1. Is this common? I don't see any TSBs for it. Has anyone seen it before?
2. How can I fix it?
I don't want to purchase new calipers. New bolts? Possibly parts missing after the latest brake job (before my purchase)? I saw some bolts with silicone inserts online for this issue but I'll be surprised if I'm the only one with this issue.
Thanks in advance!
-Eric
Old Jun 1, 2018 | 03:15 PM
Surfnazi's Avatar
Surfnazi
Take caliper off clean off rust buildup on mating areas and bolt area see if that helps
Old Jun 1, 2018 | 07:35 PM
llebcire's Avatar
llebcire
Thanks!
Should I plan on replacing bolts or getting new hardware kit?
-Eric
Old Jun 4, 2018 | 01:29 PM
Surfnazi's Avatar
Surfnazi
I would it's cheap insurance since you're taking time to take apart and clean btw they sell spray at lowes home depot part stores that stops and stabilizes the rust so it stops and you can paint over it
Old Jun 4, 2018 | 01:39 PM
slartibartfast's Avatar
slartibartfast
Good god, that's almost impossible to understand. Punctuation, man!
Old Jun 6, 2018 | 06:13 AM
Surfnazi's Avatar
Surfnazi
Man do you ever not try to come off as a pompous ***?
Old Jun 6, 2018 | 07:50 AM
llebcire's Avatar
llebcire
I'm finding the hardware kits are about $5 whereas I can get a hardware kit with new pads for $24 (Power Stop or Raybestos). Should I get new slide bolts? I found a post in Mustang forums where someone had a similar issue due to worn slides. My guess is the previous brake job wasn't done correctly and the hardware may be installed incorrectly (or bent) and the slides may not have been properly lubricated.
I'll get hardware, possibly slides, clean everything and use caliper grease to see if this resolves the noise. I can't imagine the calipers are bad, although I wonder if they need rebuilt as my understanding is they should keep slight pressure on the pads at all times and if they aren't could allow a rattle. The caliper rebuild kits are inexpensive ($3/side) but I've never rebuilt a caliper and could run into issues if I mess it up.
My wife saw the video and said "those are rusted - should you just get new ones?" I'd love to but upgrading would be $500 as I would get 4 piston which would require 350mm rotors.
Thanks again for your assistance - any more thoughts on what I should do?
-Eric
Old Jun 6, 2018 | 10:19 AM
Surfnazi's Avatar
Surfnazi
Stoptech kits comes with complete with pins,guide pktes,bolts, rotors and pads. You can get front and rear for 500 or so
Old Jun 6, 2018 | 04:31 PM
slartibartfast
The point of this board is to share information. If you post unreadable crap, no one benefits.
Old Jul 2, 2018 | 12:07 AM
llebcire's Avatar
llebcire
Fixed it!
Replaced pads, hardware and caliper pin boots yesterday and cleaned and properly lubed everything - sound is gone! Thought I recorded a video at the end but it is unbelievably hot and humid here and I apparently forgot to hit record? Cost me $40 (Rockauto) and about 1.5 hours of time.
This was really bugging me and it’s refreshing to drive the car and not have it rattle over bumps.
Thanks for all the help!
-Eric
Video when starting yesterday morning (noise starts @ 1:12):
Old Jul 4, 2018 | 03:13 PM
llebcire's Avatar
llebcire
Here's the first video along with several others pieced together - no editing to speak of.
Old Jul 4, 2018 | 06:24 PM
Surfnazi's Avatar
Surfnazi
https://youtu.be/DKB35oP_kgA
Nice work. Why didnt you apply the rust inhibitor to the calipers since you were there to prevent rust? Besides stabilizing the rust you can also paint on top of it. I used the high temp engine block paint since it's good to like 800f and wont heat fade the color.
Old Jul 4, 2018 | 07:06 PM
llebcire's Avatar
llebcire
Great question!
My plan is to paint the calipers and hubs black and eliminate the rust and I will still do that this summer. I didn’t want to spend the time and money if I was going to need to replace the calipers to eliminate the noise. Now that it’s gone I’ll go back and paint them.
-Eric
Old Jul 13, 2018 | 09:44 AM
llebcire's Avatar
llebcire
150 miles of quiet rattle-free driving later - I can confirm the calipers were the root of the noise the entire time.
I would invite anyone chasing front-end noises/rattles to rule out the calipers as typically end links, bushings, etc. are replaced for noise. For a week I had a 2010 G37x with 60k miles (returned due to paint issues) and it made the same noise.
-Eric
AMai1215
Jan 13, 2015 12:54 AM
ManU07
G37 Convertible
Jul 5, 2013 09:18 AM
onthefence
Jun 18, 2013 07:40 AM
madeyalook
Jun 11, 2013 06:27 PM
swilli4424
Nov 20, 2011 11:30 AM
