PDA
View Full Version : Brakes, Suspension, Wheels & Tires
Pages : 1 2 3 4 5 6 7 8 9 10 [11] 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37
  1. Chicagoland G members
  2. 2004 RX-8 wheels on G37s coupe fitment
  3. Should I order 245/275 or 255/285 tires?
  4. Need Help
  5. Need help replacing break Pads & rotors for 09 G37x
  6. Anyone put G37xS Sedan Wheels on their G37xS Coupe?
  7. Power brake bleeder
  8. Super Noob Question Regarding Lowering Springs
  9. Help What wheels are these?
  10. Rack & Pinion? Tie Rod? Boot? See Pics
  11. 2013 G sedan, grinding feeling in brake pedal?
  12. Help IPL Break wear and replacement
  13. Confused on OEM offset
  14. Will my wheels clear Akebono oem brakes?
  15. Nokian Tires
  16. Spacers on stock wheels
  17. Help Best material and source for brake pads
  18. Coilovers And Alignment
  19. Think I will rub?
  20. Alignment, frozen bolts
  21. Niche Targa M131 installed
  22. Help Which brake pad? Too many options
  23. Can you recommend a WINTER tire/wheel fit for 2011 G37xS?
  24. 2011 Sedan 20x10 +35mm Rears
  25. Source of front squeak?
  26. Help Ugg I know you guys are tired of this.... wheel question
  27. Wheels bearings, sport non-sport difference?
  28. 370z NISMO wheels as new wheel setup?
  29. AWD sway bar options
  30. 18x10 offset 42
  31. Need a little help on these rims
  32. What pads are you guys using that doesn't squeal?
  33. OEM wheels
  34. Help Install of BBK Akebono GuideLines Needed
  35. Brakes Squealing
  36. Bushings. Which and where to get?
  37. Help!! Lowering Spring Question
  38. Help Need part numbers for Lower and Upper Control Arms (sedan)
  39. Brake pad size question
  40. Wheel fitment
  41. Rear camber arm options
  42. Need bit of help staggered on X
  43. G37x Coupe Struts Question
  44. Ordered Ksport Kontrol Pro for g37x sedan
  45. Odd tire wear
  46. Help recommended brake shop near northern nj
  47. 245 vs 255
  48. Help would akebono clear 09 g37x coupe 18in?
  49. Will 285s work on OEM 9' Wheels?
  50. Safe to Travel with spacers??
  51. Help sport springs on a awd??
  52. G35 Rays on G37
  53. Stock oem staggered sport wheels
  54. Lowering & Wheels
  55. Akebono Stencils
  56. Jumping from 17" to 19" wheels
  57. Help My 2012 G37 Sedan has bent subframe??? please read
  58. Help! Car feels like it's going all over the place!
  59. Round 2 of Staggered Wheels with Square Tires - TSW Bathurst
  60. help me with best wheel fitment!
  61. Carbotech part #?
  62. 320mm pads: Carbotech vs Stoptech vs Hawk?
  63. Brake noise
  64. Need Help
  65. G37xS suspension vs Q50S awd
  66. Tanabe pro soc and pro comfortr
  67. 18' staggered vert wheels on 08 g35xs sedan
  68. Coilovers & Camber Arms & Tucking???
  69. Sport Akebono BBK standard?
  70. FYI: 2009 TPMS Sensors do work w/ 2011+ G37's
  71. Another Brake/Rotor Thread
  72. Help Powercoat or not to powercoat. That is the question
  73. The Struggle of Deciding on Wheels
  74. TEIN and their coils...thoughts?
  75. Humming noise from my 6MT Coupe
  76. Help caliper piston won't compress
  77. Help 2009 G37 Sedan (non-sport) Dropped on Eibachs - Spacers and Camber question
  78. Help What do you think of these wheels for G37xS?
  79. Best deal on Akebono bbk?
  80. Weird noise near driver side rear wheel
  81. handling help, need suggestions
  82. Some questions for the brake gurus
  83. Help How to be track day ready for G37 noob?
  84. Preload: FrontEnd floppy Too Much or Not Enough
  85. Tl DR; Glad to be out of the PSS (kinda)
  86. Floor Jack for brake jobs
  87. Help Part number for original wheel?
  88. Q60 AWD Will these wheels fit??!! 19x10.5 et30
  89. To lower or not to lower....that is my question.
  90. Help Rubberband like feeling when hard braking
  91. Fortune 500 Coilovers and Camber Plates
  92. Help I live in Chile, so I need help eibach pK or Swift sport and avantgarde M368
  93. Help Rotor Research
  94. tire fitment
  95. Vibrating/humming noise
  96. A problem with my spacer.
  97. Help Raising my G37S
  98. Multipiece wheels and Akebono BBK - What Disk Type?
  99. Review Pictures of G37s Sedan with G37s Coupe Eibach Springs
  100. Lowering Advice
