PDA
View Full Version : Brakes, Suspension, Wheels & Tires
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37
  1. Should I change inner tie rods if changing outers?
  2. Front end violently shakes at certain speeds
  3. Anyone just lower front end to match rear?
  4. Coilover install extras?
  5. Wide Body Kit - X Sedan Wheel Measurements
  6. Help Front end clunk
  7. Help Power steering leak from pump
  8. Help Powersteering pump leak (Replaced 2twice)
  9. Help Staggered Tires on Stock 18in wheel
  10. Help 2012 sedan base model with Akebono BBK
  11. Wheel fitment help
  12. Help Direct fit OEM rims for 2012 G37xS
  13. Remove front sway bar for drag racing
  14. Help M14 wheels on M12 studs
  15. Stuck FL strut bolt on LCA
  16. Help $1,660 to Replace Rear Stay?
  17. 255 tire on 8" wheel - bad idea?
  18. Will these fit?
  19. OEM 19" Sport Wheels on Non-Sport
  20. Velox Wheels?
  21. Airlift 3p not turning off when car is off
  22. Help Looking for a solid all-season tire. PNW Rain
  23. Does the G37 share the same suspension components as G35?
  24. Bad wheel bearing?
  25. Help 19 inch wheels on G37x Sedan
  26. Help 19 inch wheels on g37x sedan
  27. Help G35X hub/wheel bearings replaced and now the speed sensors seem out of wack
  28. Help stripped lower strut bolt
  29. TPMS confusion
  30. Do the base 320mm sedan brake rotors fit g37 coupe base
  31. Where to drill for top adjusters on coilovers like feal/fortune auto
  32. Running divorced springs with true style coilover shock
  33. Help Need help deciding on tire size
  34. Coilover’s & Stock Rims
  35. PLEASE HELP! Failed Inspection - Leaking Front Right Strut
  36. Sport vs standard end links the same?
  37. Michelin Pilot Sport All Season 4
  38. 11’’ rims camber adjustment
  39. My personal coilover saga
  40. Help 2008 g37 brakes went soft while driving
  41. 18x9.5 fitment on G37s coupe
  42. Help Stripped brake caliper mount
  43. Tires for duck feet 18x7.5
  44. Tires for 18x9.5 AWD
  45. Strut brace or sway bars? Which ones?
  46. 09 Brake pedal will not depress
  47. 2010 Coupe G37 New Brake Pads (Sport BB)
  48. Help Tire maintenance
  49. Help High hissing noise when braking a little bit
  50. Rusted out front crossmember
  51. Question about wheel spacers
  52. 13 G37X AWD Sedan Front Suspension Crossmember Cage Frame Cradle
  53. Help Coilovers that offer the most low?
  54. Install of Coilovers
  55. Has anyone used Z1 Upper control arms?
  56. winter rims
  57. WTB suspension parts. (Eibach sways, UCR’s, Swift springs)
  58. Front STOCK sway bar thickness AWD
  59. Another dumb simple tire size question cuz I suck at this
  60. Help Tanabe NF210 Springs for Coupe on a Sedan
  61. Help 2010 G37xS sedan pull to the right and vague steering
  62. Putting sway bars on. What stiffness for front/back?
  63. Will the G37 Akebona brakes fit on a JX35/ QX60?
  64. Help Tire/Tire size options for 2012 G37X 18"-7.5" OE Alloy Duck Feet Wheels
  65. Squeaking under movement while loaded
  66. Help Wheel fitment issues
  67. The revenge of the axle
  68. Nismo away bars with g37x end links
  69. 5X115 on a G37x Sedan
  70. Federal SS595 or Toyo ExtenzaHP II
  71. Factory Springs & Bars: The List
  72. Looking at getting new calipers and pads. What brand?
  73. Help Hotchkis swaybar bushings
  74. Will after market sway bars improve my car?
  75. Helping picking best Tire Size
  76. Rear Subframe Bushings Replacement Help
  77. Sport suspension
  78. 20" wheels on road trip
  79. Brake Pad stuck
  80. 2013 G37X Sedan Replacement Wheel
  81. Is this normal?
  82. Sway bars any help?
  83. Alternatives for Michelin Pilot A/S 3+ Tires
  84. Fitting 17” Wheels on G37S rear
  85. Help Infiniti g37x awd bc coilovers br type
  86. Steels rims for 18 inch
  87. 2013 G37xS Coupe AWD - OEM wheel specs
  88. Opinions on spacer size
  89. Akebono
  90. Help Lowering Springs check
  91. What's the widest?
  92. 6mt Steering rack replacement
  93. Weird Noise from Engine Compartment
  94. Poll on brake pads for DD/Spirited Sports
  95. Need some help with a steering rack replacement
  96. Help Best bang for your buck handling upgrades?
  97. 08 G37s Steering?
  98. Creaking from front right suspension
  99. Help Squeaky/rubbing noise with slow turns
  100. 2011 g37xS humming/vibrating noise starting at 40mph and above
