- 18 x 8 wheels?
- Dead Spot In Steering
- Help Rear Differential Bushing Install Gone Wrong
- Car randomly pulls to the right while braking
- Help Alignment issues
- G37s Sedan RWD Spacer/Alignment suggestions
- 2013 G37x PSF Change
- Help Humming Noise
- Moog Sway Bar Endlink Fitment? AWD Sedan
- 2012 G37x Heavy Front Wheel Vibration - Low Speeds
- Wheel setup jnc
- Shocks or Struts? HELP
- Help Steering wheel vibrates at 70mph
- Help Help on tire and wheel fitment
- STUMPED with power steering leak. PLEASE HELP
- Summer hi perf tires in winter
- Help New camber kit?
- What tire size for 20x11.5 & 20x10.5
- Need help deciding between 2 rims!
- Newbie- 2013 g37x sedan wheel options
- G37 steering wheel making noise burning smell when turning
- Reducing power steering boost
- Help Vibration from 110km/h
- Still no power steering after rack and pump replacement
- Help Eibach or Swift Lowering Springs?
- Tein Flex Z coil overs
- Will i need extended studs for spacers
- Will OEM 17" wheels clear the Akebono brakes?
- Rebuilding Brake Calipers, Cylinder Has a Scratch. Is This a Problem?
- Larger Spare Tire
- Brakes and Rotors
- Front End Squeak
- Knock when turning wheel at low speed
- 275/35/19 front and rear
- OEM Akebono fitment question
- Can dealer void warranty - 245/275?
- New wheels **** up my g37
- Steering Rack leak
- Stabilizer bar links, alignment necessary?
- Is my G lowered?
- Banjo Fitting Brake Lines on Akebono Calipers
- Turning Rotors
- Anyone running alternate tire sizes on G37x or Q40 AWD? ?
- Reducing Unsprung Weight: G37 Benefits?
- AKEBONO discoloration after brake bedding procedure!!!
- Just got my alignment done. Look good?
- Bagging my G37 sedan
- Rotors warped after tire rotation?
- Lowering G37
- Help Can’t decide if I should get drilled/slotted rotors with ceramic pads or not
- Alutec strut tower brace installed
- Vibration and clicking noises
- Stiff Steering after after run off the road
- 2011 G37x Steering Lock
- Help Bad rust
- squeeking front suspension
- Help Negative characteristics after alignment
- New Tires/Brakes 2010 G37S Coupe
- Help Power steering stutters and doesnt work while car is idle
- Help Constant Tire Blowout
- OEM Suspension Overhaul 2013 G37x
- Possible failing steering rack? Car wandering, off center
- Rack and Pinion, seeping from boots
- Need Help making up mind Coils VS Spring/Struts
- "Pretty" rotors recommendations?
- Thoughts on D2 Coilovers for g37 coupe
- Squeaky Steering, very high pitched
- Help 2008 G37S Coupe with 285/35/R19 mounting issue.
- Help The untraceable squeak and clunk
- Rims
- Help Recommendations for a red strut/sway bar?
- Symptoms of Bad Upper, Lower Control Arms
- Warped Rotors need new ones 2010 g37X
- Hmm...wonder what that clunking sound in the rear was from?
- Any brake caliper upgrade options for 17x9 et25 wheels?
- Akebono bbk piston not releasing
- Brake Light Switch?
- rack & pinion leak possibly?
- Power steering pump
- BBK Upgrade
- Help Upper Control Arm Rubs Against Tire
- Wheel fitting with spacers [please help I’m dumb]
- Help needed on Left lower ball joint loose.
- Brake, ABS Light & VDC Off ---- Help Please
- Fighting the Wheel
- Dealership Do Bad Alignment?
- Brake pedal issue
- Spacer Size Recommendation
- Got Threepiece Work Rims and was wondering what lock lug nuts to get
- Akebono & rotors
- Tool review/recommendation
- Bad control arms vs coilovers
- G-FORCE COMP 2 A/S Tire Wear Question
- Before I Buy Swift Lowering Springs RWD
- Are D2 Coilovers True style?
- Knocking from going over bumps and sometimes turning
- Help Are these OEM wheels a factory finish
- Widest wheel size without looking silly?
- Do these OEM 19" rims clear big brakes?
- New OEM Rims for '13 G37X
