Help Rear coilovers
You can but the suspension will be mismatched, spring rates will more than likely be quite a bit firmer than your Tanabes (which are some of the lowest spring rates for aftermarket drop springs). I'd just use the full set of coilovers, you can still get the height that you like in front and will have more adjustment available for damping and overall height.
S4_STI_G37
Jan 2, 2013 01:23 AM
