PDA
View Full Version : Brakes & Suspension
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41
  1. Is alignment immediately necessary with Tein H. Techs?
  2. Best bang for your buck rotors for BBK
  3. coilovers for g37
  4. G37xS Coupe Suspension
  5. Best Brake Pads for my g37
  6. Aftermarket sway bar owners
  7. Saggy rear end with lowering springs..
  8. Suspension (Most Comfortable Coilover?)
  9. 12 G37xS Rotor Size
  10. Ferodo DS2500
  11. Lowering on OEM 18 inch wheels
  12. Caliper paint ideas"
  13. G37S Brake pads
  14. Has anyone heard of these springs?
  15. KSport now has coilovers for verts
  16. Strut mount issue and installation
  17. need part number for brake pads and rotors for 2011 g37x sedan
  18. Loose handbrake?
  19. UAS Bags on BC Coilovers - G37 coupe
  20. AirLift Performance Air Struts - opinions???
  21. Wheel bearing warranty coverage vs Swift springs
  22. Anyway to make my G37x feel like a Q50S?
  23. Brake fluid leak- 1 man bleeder?
  24. Airride from Air Lift
  25. How low can your X sedan go?
  26. Quick Swaybar X question
  27. Help Corroded brake fittings and top of caliper
  28. Track Day! The "Sport" Rear Sway is a MUST for X/XS Owners
  29. Tein Basis vs. Swift vs. Swift with Koni shocks?
  30. g37 braces?
  31. Unique way to install AIR to a VERT!!
  32. Tein s techs for g35coupe vs g37coupe
  33. Looking to install Akebono calipers (NYC)
  34. squeaking noise when pressing brake
  35. Those with Swifts, did you change shocks/struts?
  36. What spacers will I need for 18" wheels on 2009 X Coupe with Akebono upgrade?
  37. what setting do you have your hotchkins sway bars
  38. Alignment Issue
  39. g37S springs on g37xs work?
  40. Stop tech BBK, sway bars, and strut bar; installed
  41. Help Lowest Ride height without camber kits?
  42. swift springs too stiff; will new shocks/struts help?
  43. Ride Heighth
  44. Sedan guys with KW - what heights are you running?
  45. The choice of coilover between BC Racing & Tein in Taiwan G'
  46. Squeaky brakes
  47. non-sport brake job cant remove caliper
  48. Help rubbing on Tein S-Techs
  49. Air Ride Recommendations
  50. Lowering My G37 Coupe...
  51. Poll. Are strut braces worth it?
  52. Z1 has new front upper control arms.
  53. Suspension/ coilovers
  54. Swift springs ID too large
  55. (NEWB) Does the BBK fit with 2011 G37 Journey Coupe? (Stock wheels)
  56. Lowering question
  57. Need opinion on these rotors
  58. Best coilovers ? Best sport suspension
  59. New clean photos on swift springs (AWD)
  60. Brake Judder solutions
  61. Akebono upgrade on '11 G37x sedan
  62. G37S Brake job
  63. Just Installed KW V1's....Couldn't Be Happier With This Setup
  64. Tanabe Strut Tower Brace installed on Coupe
  65. In your opinion - best bang for buck camber & toe arms?
  66. Alignment specs... Opinions?
  67. g37x springs
  68. Sway bar part #'s ?
  69. Rotor and Brake Pad Recommendations
  70. Need your G37x SEDAN lowering spring info
  71. Another G37x with swift springs installed
  72. Cost for Camber kit install
  73. Swift Springs for AWD
  74. 2010 G37X Sedan Rotor Size 320mm or 300mm
  75. HELP....spring or coilover for 2011 G37 sedan?
  76. Brake squeal when not braking
  77. Ten Basis setup instructions?
  78. Front brake pad issue???
  79. Swift springs G37x sedan
  80. Feeling at slight shudder at speed (70+)
  81. Front Strut Tower Nut Replacement
  82. Performance suggestions
  83. What is needed to lower
  84. Dead Horse Maybe? Springs and struts or coilovers?
  85. Help - Airrex Suck!!!
  86. Scale Coilovers
  87. G37x coupe brake kit question, Please help!
  88. Finally! (Akebono)
  89. Suspension and brakes for AWD sedan
  90. Brake Pedal Squeak
  91. Damn strut bolt
  92. 2008 G37S Coupe replacement rotor dimensions?
  93. Stainless steel brakelines question
  94. Help Akebono BBK installed. No pressure on brake pedal after bleeding the brakes!
  95. Dropped G37x, Megans racing Coilovers
  96. Stronger Axle Boots
  97. Help Missing Rubber Piece Akebono BBK
  98. Which rear endlinks do I want?
  99. Just had my Eibach springs installed and love them
  100. help!
