- raising my car back up from Eibachs
- Rotors warped - Need Advice!
- Help Stance Coil Damper Adjustment
- Help me PLEASE with these strange turn of events...
- Springs Install? $$$!
- How much should it cost roughly to replace brake and rotors?
- Photos of Sedans with Tein S-Tech Springs or H&R springs
- Tein Springs help!
- Rubber squeak noise after lowering and sway bar mods - G35X Sedan
- Help Kw v3 question, please help !!
- Please please help ....caliper mess
- GTSpec FSTB Installed - decent results
- Help Camber Corection w/ H&R
- Dealer can't do alignment
- What color caliper goes with Liquid Platinum Sedan?
- TEIN S.TECH Lowering Springs Questions
- Anyone here with aftermarket suspension bushings?
- Will 2012 G37 Sedan springs fit on a 2012 Coupe?
- What's this thing on top of the strut?
- Front ball joint integrated into control arm?
- Are these new akebono brakes?
- Springs help
- Hotchiks sway bar causing creaking sound: Solved!
- 2011 G37 Coupe Sport Brake caliper covers
- IPL \ Coilovers
- Best pads for street with slightly better bite than oem?
- Should I paint new akebono bbk?
- G37 2012 IPL suspension on v36 sedan?
- Rear wheel hub Replacement
- Help Lowering my IPL
- NEW Coilover system for AWD (Response Needed)
- Used Eibach's?
- Review Lowered the sedan
- Proper steps to drop?
- Cusco strut bar installed
- Need help deciding on Rotor / pads Combo + Where to purchase! ASAP
- Help Need help deciding on Rotor / pads Combo + Where to purchase! ASAP
- rear strut removal question
- BC Coils with Swift Springs
- About to swap out springs and sway bars - any advice?
- G37xS lowered on Swift Springs
- Help kw3 vs JIC Magic FLT-TAR coilover
- Squeaking Brakes Normal?
- FIGS Engineering Lower Control Arm Camber Adjustment Interest
- Megan Coils or KSport coils
- Help Eibach Springs help!!
- Another Swift Springs Install (RWD Sedan)
- Coilover installation costs?
- Powertrix Coilovers
- What would be your color idea? Caliper Paint.
- Upgrading Sways
- X to RWD to Hotchkis Swaybars
- Special Sway Bar Warning!
- Installing Brake Lines
- eibach pro kit
- eibach pro kit
- Swift RWD Sedan Springs Installed! In-depth Review!
- Help H&R or Eibach Springs (G37S Sedan)?
- Help Busted a factory strut
- Yellow Speed Racing Coilovers
- 2009 G37 Shocks/ Stuts
- D2 coilovers for the vert or bc ?
- Got my calipers painted
- Swift or Eibach lowering springs for G37S RWD sedan
- Sluggish/Slow Steering Wheel Lock
- Need some help: unstable/floaty feeling at highway speeds
- Brake pads already??
- Springs! Advice
- Going from lowering springs (Eibach PK) and OEM shocks to coilovers (BC/D2)?
- HELP-Question about Odd Sound From 2009 G37 Coupe
- Hotchkis sways vs G37S rear only
- Help What's the part # for the Akebono pads that come with the BBK on sport models
- Help best brake pads?
- Eibach prokit + camber kit + alignment quote
- Help Calling all Eibach users
- HELP!! Warning/Indicator Lights when Mashing Gas
- Suggestions for SS brake lines
- Front End Metallic Sound
- Hotchkis sways - which setting for the front?
- Eibach sway bars-squeak
- Help SPC Camber Shims Necessary ?
- Brakes!!!!
- Toe Settings with Negative Camber 2010 G37S Sedan
- Rear Lower Control Arm / rims
- possible suspension problems need help
- Uneven brake pad wear
- 2012 g37 coupe journey suspension
- RWD OEM front brake pads on an X?
- ARK Performance G37 Convertible Springs: Now Available!
- Clunking/Squeaking from passenger front
- Little help removing the rotors please
- Looks like an alignment issue?
- Who makes front end links for the G37X sedan?
- Help What I need to know about Air Ride?
- Drilled Slotted Rotors
- Which front end links with Hotchkis sways? Do I need new ones?
- lowering g37 question
- WANTED: Tanabe NFS210 front springs
- Brake light and vdc turning off while accelerating.
- G37X Brake Issue
