- Non-sport brakes suggestions
- Eibach Sways for Vert
- Brake wear?
- Do i need new brakes?
- Hotchkis vs. GTspec
- New Rotors and Pads. Softer pedal
- RICE.. Who G37 is this with Fake Red Brembo Brakes
- Rust forming near brake rotor - is that normal?
- Powdercoating
- Something loose?
- my steering wheel shakes when I hit brake
- SPC Camber Kit fit the G37x sedans?
- Coils and spacers question
- I need help with springs!
- -2.5 camber when lowered
- Best BBK for G37 Sedan
- KW Coilovers for Vert?
- Help Wilwood BBK up front, OEM brakes rear... opinions?
- Auto brake application?
- Brake Judder TSB Help!
- 6 piston caliper vs 4 piston caliper in the front
- Tanabe Sustec Proc C "Lurching"?
- Dealer quote for REAR only brake job.
- Going low!
- Daily driven (snow), springs or coilovers?
- Akebono BBK upgrade questions
- opinions on color for brakes on vibrant red
- 2011 g37x sedan wanting s brakes help
- G37X Coupe Dropped on Eibachs
- G37s owners, any of you know the brake diameters on the Akebono's?
- Stupid idea or genius??
- did anyone use BC coilcover before
- Eibach Pro-Kit for 2011 G37X
- Help i THINK my rear end-links are shot
- Another Eibach post
- Eibach & alignment fail
- How much brake fade is normal?
- Eibachs creaking
- Swift Spec-R Springs!!!!
- Parking on a hill / Using E-Brake?
- Hotchkis sways....
- Eibach pics please
- Dealer quotes a Akebono BBK install
- 2009 G37s 2011 G37s
- Well X will be dropped next week.
- help!! tein basic or tein flex?!?
- TANABE SUSTEC PRO S-OC or STANCE GR+?
- Front Camber kit question..
- Building a suspension wishlist...
- Drop just the front?
- rear brake squeal
- Regular rotors or drilled and slotted?
- Want to Drop my X Coupe
- Finally Dropped
- Drilled Rotors for 07 G35X
- G37x sedan looking for a eibach drop
- Coilovers Help!!!!
- Help with Akebono BBK
- Do springs blow struts?
- Help Adjusting coilovers?
- Tein S-Tech vs. Eibach Pro Kit
- Anyone have problem with front brakes rubbing?
- G37xs brakes....what are the Best rotor and pad combo?
- Anyone have this problem too??
- How much do springs settle?
- Bc racing
- Steering wheel pulling to one side
- Crossdrilled / Slotted Rotor Owners - Who Turns your rotors???
- Becoming frustrated at the lack of suspension parts for the AWD cars
- g37x is too high...springs!
- Yes I have made another coilover thread, but hear me out...
- G37s brakes
- Brake Issues
- Will the Akebono BBK fit a 2011 G37xS Limited Edition?
- Help For you X guys on the Eibach Pro Kit...
- Group Buy (Brembo Gran Turismo Brake Kit)
- Vibration when braking at 120+kph
- SPC performance camber kit for the vert
- I know guys...I know but Eibach or H&R or S-Techs?
- Tein Basic Coilovers or Megan Coilovers
- Installed Hotchkis swaybars 2010 G37xS
- BC Coilover height
- Ruggedness of BC coilovers? well ill tell you
- Slip warning light
- 11 g37xs dropped
- damage from sway bars in the long run
- I Love G37's hydraulic power steering !
- Best drop for a daily driver
- springs/alignment
- H&R roadster/vert springs for g37, will you get them?
- Vert owners: H&R vert springs are released march 2011!!!
- Brake squeal solved
- PG 2008 G37S with Eibach Pro Kit, Camber results with no camber kit
- Toe Way off after rear drop
- 2011 G37x lowered on Eibach pros
- Alignment sheet posted.SAI/AI WAY off,new G37x,3 huge potholes, PLZ READ...
- Eibach Pro kits and shock/strut?
- just got alignment done....feels strange?
- Help Spacers/ Hub Centric Rings
