- G37X Sedan With Stance Coilovers
- Lowering springs ( Eibach ) questions
- X Coilovers
- Installed Cusco Strut Brace- Questions
- KYB GR-2 versus Monroe vs Stock
- G37s Sedan Stock Ride Height
- Swift spring or Eibach?
- Coilovers??
- 4 Wheel Steering and lowered
- Will I make it over speed bumps?
- front end rattle solution
- Akebono BBK pads: where to buy??
- Vert Shocks/Struts
- Questions about going from non sport to oem akebono brakes
- G37x Fortune Auto Review
- 2007 G35 Sedan Suspension Parts & Rebuild
- Motordyne vs Hotchkis Sways?
- Brake change help please
- 2012 G37x on coilovers and gtr stock wheels
- Swift awd sedan Springs On a rwd sedan
- For new Sway bars New endlinks required?
- Anti-lock braking sounds terrible
- Air ride help
- G on HKS Hipermax GT IV. Anyone else have them?
- New Tein flex z series coil?cheap sealed street flex
- Z1 Front upper control arms installed
- Scratch in brand new rotor
- Anyone have experience with Swift Springs on a G37S coupe?
- Rear Brake Squeal..Again
- Brake Pad Recommendation?
- New to posting just bought g37 vert quick question on oem caliper
- Help Alignment Woes
- Rear Swaybar from RWD on AWD. How much of a difference will this really make?
- Question for people who had their brakes replaced by dealership.
- SPC camber/toe bolt instructions & template
- Anyone have tanabe comfort r coilovers ?
- Help Slip light flashing / Vdc lights on
- Help Just another thinking about going Air thread
- Lost and confused about brakes.. Please help!
- FA 500 owners...
- lowering spring set up
- ? about camber and airing suspension
- SPC front camber kit and coilovers
- Weird noise/cringe when I hit bumps/dips
- This blows me away - Stoptech rear pads are worn out after only 10K miles
- SPC rear arm/toe with two part numbers?
- Thinking about the suspension
- Alignment adventure.
- Why does my coupe look like it has a reverse rake???
- Coiler over and sway bar
- Coilovers and camber kit! AWD
- Swift Spring with camber kit on 2015 Q40 AWD
- Question about OEM Springs
- Still Can't Solve Brake Judder
- What Rotors & Pads for 2011 G37x
- Time to replace rear sway bar in awd compared to install front sway bar in awd?
- Aftermarket RSB feel any different on my car?
- 2011 g37x coupe AWD light blinks briefly
- what kind of Suspension should i go with
- Coilover Question
- coilover question
- Tein Basis Coilovers? Yes, no?
- 2010 G37 Journey front end clunk
- Lowering springs, what shocks?
- Help G37XS Coupe - Brake Pad Specifications!
- Proper way to install coilovers on an X
- Centric Rotors for G37 Sport | StopTech vs Hawk HPS pads
- Do you activate ABS during brake flush?
- The effects(or lack thereof)of not having camber kits
- VDC, Slip, and Emergency Break Warning Lights
- 3POINT8 found new lowering springs for the vert!
- P-coating calipers and new rotors - SS lines and Project Mu pads?
- power steering leak
- Is This Brake Dust or Road Dirt?
- Help Needed. Brake Change/Leak
- Lowering springs and wheel spacers idea?
- Help Infiniti G37 akebono brakes..
- Hotchkis Sways
- Is this a good deal for complete air ride setup??
- Help Air ride trunk setups?
- after market springs?
- Replacement SPC Ball Joint
- G37x Sport caliper covers on NON-SPORT G37x
- OEM Rotors & Brakes vs EBC Rotors & Brakes
- Rear rotors warped??
- Springs
- lowering springs
- Review BC BR Type Coilovers + '12 G37xS sedan
- Help Going air...remove or trim felt liner?
- How often do u guys scrape on a mild drop?
- DBA Brake Kit - Seeking Feedback
- Help Right Rear caliper piston always sticking
- Am I Being Taken?
- Brake Fluid Expiry?
- G37x rear end squirrely after inadvertant drift
- G37x brake questions
- Akebono brake pad clips
- Drop Knuckles/Spindles
- Help Suggestions for New Rotors / Pads
- HKS Hipermax IV GT coilovers for G37x (AWD) Sedan (non-sport)
