Quick Swaybar X question
Old Sep 22, 2015 | 03:27 PM
DeepakG37's Avatar
DeepakG37
Recently bought the Coupe S sway bar for my X sedan, wondering if I could use the same brackets as OEM one as I didn't get the S OEM brackets to mount it
Appreciate the help.
Old Sep 22, 2015 | 03:33 PM
Ryne's Avatar
Ryne
The Steering Wheel Guy
The same bracket will work, but you do NEED the bushings from the larger sway bar, which will fit into the existing bracket. The reason for this is that the diameter of the bar is larger.
Old Sep 22, 2015 | 03:53 PM
jason05gt's Avatar
jason05gt
I am interested in this as well. In another thread, a member mentioned Energy Suspension rear bushings for the Sedan or "S" rear sway bar. Does anyone have a link to where I can buy new rear sway bar bushings?
Old Sep 22, 2015 | 03:57 PM
Ryne's Avatar
Ryne
I used the OEM bushings for the RWD rear sway bar. They are a perfect fit. If you go with a polyurethane bushing you may have noise issues as they are prone to squeaking.
Old Sep 22, 2015 | 04:22 PM
jason05gt's Avatar
jason05gt
Thanks! I was thinking the a poly bushing would compliment the stiffer rear sway. I have Energy's poly lube in the garage, so that should help keep squeaks away.
Old Sep 22, 2015 | 04:35 PM
defektion's Avatar
defektion
While you're down there installing your new sway install some new end links too.
Old Oct 1, 2015 | 04:09 PM
jason05gt's Avatar
jason05gt
Just picked up a 370z sway bar on ebay for $50 shipped. I plan on installing it with new bushings, so I will post a review after.
Old Oct 21, 2016 | 05:20 PM
peterso2's Avatar
peterso2
how did that go Jason?
ScrewstonNismo
Sep 15, 2015 10:34 AM
Falker11
Sep 9, 2015 08:53 PM
carid
Supporting Vendors
Sep 9, 2015 10:41 AM
Detailed Image
Lighting/Cleaning Products
Sep 8, 2015 02:39 PM
