- BC BR Coils installed, clunking from rear passenger
- Caliper question
- Help quick question front lower control arm
- Willl installing Hotchkis sways void the warranty?
- Hypertech latest update with TSB 027/a
- Hotchkis + Ark guys
- Front End Links
- Help Need to raise the front
- Brake rust
- Replacement Brake pads for 2010 AWD Sedan
- Can I put a spacer under top strut mount?
- Oooohhhhh Modme.....
- 09 vs 10 G37X suspension - any change?
- So frustrated!! Brake Roors not fitting
- G37X--front suspension problem--anyone else?
- X drivers with Hotchkis Sways
- Springs?
- Need som brake seals
- Longevity of OEM shocks with Eiback springs
- Eibach/SPC Front & Rear Kit
- What color should I paint my Calipers?
- brake cleaner
- No access to damper adjustments rear coilover on top on 2011 G37S sedan??
- Anyone have any experience with rotors/pads from Brakeperformance.com?
- Stance Super Sport Coilovers
- Sway bar question
- g37 and g37s drop difference?
- Eibach Pro Springs (Camber Kit HELP!)
- coilover help
- 370z springs on X (Swift alternative?)
- What's this squeak in the rear suspension on my 6MT Sedan?
- PADS and ROTOR recommendations?
- 39k miles...brakes
- g25x eibach springs
- ride stiffness
- Help How many times can OEM rotors be turned?
- Bedding Procedure for new Brake Pads & Rotors (Procedure & Video)
- G37S - Squeaky brakes and recommended new pads
- X sedan Swift Springs review
- Is this the best Akebono BBK deal?
- Lowering Springs Info For Sedans
- Brake fluid
- 2008-2011 springs on a 2012 coupe
- Lowered my 09 sedan on eibachs yesterday
- StopTech Drilled & Slotted Rotors (Advice on Pads Please)
- H&R springs on X sedan??
- X guys... Talked to KW today
- question for sedans with KW v3 or similar coilover design
- Upgraded Endlinks for Sway Bars?
- are the stance coilover system the same
- Swift Springs RWD Sedan
- Stock height measurement
- Drilled & Slotted Rotors & Pads ADVIVE
- KX V1 coilovers
- Alignment Question....
- G37xS sedan sport suspension?
- What coils for xS sedan?
- Anyone using D2 coilovers on their g?
- Slave Clyinder bad expierence... 2nd one?
- Anyone try these?!
- G37 X and Suspension Braces
- what coilovers should I get. please help!!!!!
- Quality mid priced rotor replacement option for akebono?
- Help HELP Eibach Front Sway Adjustment
- Tanabe DF210 Springs? (10' G37S Sedan)
- Help Suspension gurus get in here!!
- KW V1 Coils Coupe vs Sedan
- brake help
- Help need some info
- 2010 G37S Sedan: Tein S-tech VS. H&R Springs?
- KW VARIANT 3 COILOVERS fit 2011?
- Good first mod? (For those Hotchkis guys...)
- Low speed groan
- J.I.C Magic To Come Out With New Coil-Overs
- Best (and most reasonable) drop for G37X Sedans
- GTSpec Strut Brace Installed
- Kw wtf!!!!!!!'
- 2010 G37x sedan camber kit
- Eibach Coilovers
- How can i get my Eibachs to sit slightly lower?
- Eibach Settling
- WTB Eibach Pro Kit Installed 245/275 + Spacers
- R1 Concept Rotors
- PPL with Sport Akebono BBK, jump in here plz!
- Brake pads...need your opinions!
- Drop help!!!
- H&R or Eibach springs for a g37x coupe??
- Did my Akebono BBK install today! pics inside of the process and issues!
- average price for lowering your car
- Master Cylinder Click
- got my purple and yellow parts!!!!
- Pros/Cons of true coils vs OEM style rear springs?
- Installing Springs
- COILOVERS: What do you think of these coilovers for my G.
- I want to lower my '12 G37XS.. help and suggestions please!
- Good News from SPC
- H&r and eibachs fender to ground measurements?
- A few questions about dropping my car
- Help a G35X brother out...
- Ivory White Car - Stance Sc5 Machined Rims - What color calipers?
